Amp Service - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 10:48 AM   #1
Amp service
What is the appropriate ampage for a 1900SF home here in Florida?
obie is offline   Reply With Quote
Old 08-30-2010, 11:03 AM   #2
Licensed electrician
Rewards Points: 3,658
The service size would depend on the electrical loads to be served. To calculate this you would perform a demand load calculation. A home with hot tubs, pool heaters and large A/C units will need a larger service than a well insulated home without those types of loads.
You can look on your main breaker handle to see what size you already have.
Lennox service valve questions leeh1212 HVAC 12 07-26-2013 08:59 AM
Service mast options bsperr Electrical 6 12-09-2009 08:48 AM
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 08:14 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 10:00 PM
