Is Aluminum Tape Around Power Cables For EMF Reduction Unsafe? - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Like Tree60Likes
Old 02-04-2017, 08:51 PM   #46
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,794
Re: Is aluminum tape around power cables for EMF reduction unsafe?
Turn off the breaker to the room, use candles and use wind up clocks!
Speedy Petey and ddawg16 like this.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 02-04-2017, 09:37 PM   #47
Rewards Points: 390
Originally Posted by Starglider View Post
No but I am annoying person intolerant.
Thanks!!
Please do not take this wrong, but I have been involved in numerous EMF investigations both commercial and residential, most commercial were because some equipment did not function properly particular old CRT monitors when exposed to high levels of EMF. 99.9% of the residential EMF investigations I have done the homeowner was just a tad nuts to down right freaking fruit cakes.
But they paid me and in SOME cases I was able to resolve the issue other cases I referred to a firm we work with that builds shields.
Speedy Petey and Starglider like this.
Bria Johnn is offline   Reply With Quote
The Following User Says Thank You to Bria Johnn For This Useful Post:
Speedy Petey (02-04-2017)
Old 02-04-2017, 10:53 PM   #48
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
I know all about EMIs. .........
I honestly don't think you do.
The internet is a GREAT place to get the answers you want.
LawnGuyLandSparky likes this.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
mpoulton (02-04-2017), Oso954 (02-05-2017)
Old 02-04-2017, 11:30 PM   #49
Rewards Points: 182
Can I add my voice to this without offending?
We live in a time when all manner of facts are in dispute and called false.
I have studied and practised electrical engineering for 35 years now, and I think that a fair bit of what I call knowledge of this field is able to be verified.
Here is my take on the EMI from power lines and their effect on health:
  1. Some studies have shown some negative health effects from power line fields. Many others, however, have found no such link,
  2. As far as we can tell, low-frequency fields do not cause chemical changes, they simply do not have enough energy to do this.
  3. As far as has been observed, exposure to very high levels of electromagnetic fields, such as might be experienced during a routine CT scan in your nearest hospital, does not lead to negative health outcomes.
I could elaborate, but the bottom line is that I do not think that anyone has anything to worry about from electric power lines and their electromagnetic fields.
Just my take on this, mind. I might be mistaken.
Comments, anyone?
Paulusgnome is offline   Reply With Quote
The Following User Says Thank You to Paulusgnome For This Useful Post:
Jim Port (02-06-2017)
Old 02-05-2017, 08:39 AM   #50
Rewards Points: 390
[/I]
BUT In the face some all the stories that were coming out year ago when I built my house (I built 3) I wired them in a "EMF" friendly manner. I figured err on the side of MAYBE and when the houses were going to be sold it MIGHT be a selling point.
Made no difference, 1st house sold to a single guy that could care less, 2nd house was taken by the county eminent domain and 3rd I lost to the ex.
Old 02-05-2017, 08:41 AM   #51
Rewards Points: 80
...[*]Some studies have shown some negative health effects from power line fields. Many others, however, have found no such link,
Just adding that most of those studies that I saw that did see any negative effects were along high tension distribution lines. Don't forget that they don't use a neutral, but instead multiple sets of 3 phase wiring. Extremely high voltage and current.....
The question now is, was the results of those findings because of:
* the weak rotating magnetic fields;
* or the sometimes significant leakage current through ground;
* or the fact that these neighborhoods are typically the poorest, as the lines tend to lower property values?
All are usually ignored in such studies. I've always been sceptical of studies before I read them. Statistics is just math, how you apply it requires quite a brains of said topic.
Otherwise your post was well written.
Cheers!
supers05 is offline   Reply With Quote
Old 02-05-2017, 10:10 AM   #52
Rewards Points: 680
No, you cannot. These days people tend to be either on one side of an issue or the other. There are very few who take a neutral position and are open to weigh the facts from both sides and then form an opinion based on those facts. If you promote your position, you have already offended everybody who is of the other opinion.
Here on Long Island there was a group who demanded the government investigate what they called "cancer clusters." Their position was there was some outside or artificial reason, be it pollution, power lines, or whatever, causing an unusually high number of cancer cases in particular areas.
They showed a map of Long Island and mapped out where people had cancer or died from cancer, and a casual look did indeed show that the cases were clustered in some specific locations. (No idea how they got the addresses of people who had cancer.)
After doing tests like air quality, soil samples, groundwater samples, EMF samples there were no answers and nothing pointed to the reason. Until a State official pointed out by demonstration that randomness does not mean that when you throw 100 marbles on a map that they each go their separate ways and evenly distribute themselves all over the map. Some end up here and there, but others tend to "cluster."
Further analysis showed that many of the clusters were simply high intensity neighborhoods where the lots were only 1/8 acre, and therefore the people were clustered and there was a much higher population per sq.mile, and there was little clustering in neighborhoods with 1 acre or 2 acre zoning where there were simply fewer people per sq.mile. But the incident of cancer per 100 people was the same.
So until someone came up with a reasonable explanation, the cancer cluster activists thought their theory was bulletproof, nobody could convince them otherwise, and anybody who would dismiss their theory was an enemy. (Many of them were convinced polluted groundwater was the cause therefore past industry was to blame and there would be a lot of $$$ to recoup)
We also live in a time that people dismiss any fact that doesn't cater to their preconceived ideas.
Comments, anyone?
LawnGuyLandSparky is offline   Reply With Quote
The Following 2 Users Say Thank You to LawnGuyLandSparky For This Useful Post:
Jim Port (02-06-2017), Speedy Petey (02-05-2017)
Old 02-05-2017, 10:35 AM   #53
JOATMON
ddawg16's Avatar
Rewards Points: 18,430
For all the 10 Foil hat types............
ddawg16 is online now   Reply With Quote
Old 02-05-2017, 11:12 AM   #54
That video's gonna cause some tin-foil lined heads to explode. Ahhh sheeeit.
ElectricDouche is offline   Reply With Quote
Old 02-05-2017, 02:26 PM   #55
jbfan's Avatar
Hold on to the 4th one Brian!
Bria Johnn and Starglider like this.
Old 02-05-2017, 04:42 PM   #56
Usually Confused
lenaitch's Avatar
Rewards Points: 2,056
Totally anecdotal, but I grew up in a house that backed onto 3 x 2 circuit 115kv distribution lines. spent a better part of my youth playing under them - we had the biggest backyard in the world. All good so far (65), same with my brother, dad lived to a ripe old age.
Part of the problem with 'city-folk' up here is they want all the modern conveniences but don't want any generator sites near them and howl like hell if the utility tries to increase line capacity.
lenaitch is offline   Reply With Quote
Old 02-05-2017, 05:36 PM   #57
Rewards Points: 390
I lived in Loudoun county VA, at one time the fastest growing county in America. When I moved there it was rural and population around 52,000, the population now exceeds 260,000 a few years back DOMINION POWER wanted to install new 115kv lines along their right away. The screaming and crying from all the newbies was heard state wide, My stance was you move here want AC and heat, most of the new houses have heat pumps and electric backup, not to mention lights.
They lost in court, the final karma was the guy that lead the battle ended up with a substation in his back yard.
lenaitch, supers05 and Starglider like this.
Old 02-05-2017, 05:47 PM   #58
Rewards Points: 680
Not a total loss. The sub-station is certified non-GMO and gluten-free.
lenaitch likes this.
Old 02-05-2017, 05:49 PM   #59
Rewards Points: 18
Thanks for all the input, both the informative and the amusing.
FWIW I'm removing the tape as we speak...
Thanks!!
Starglider is offline   Reply With Quote
Old 02-05-2017, 07:19 PM   #60
Usually Confused
lenaitch's Avatar
In the OP, you mentioned that you painted the ceiling with Y-Shield (emf shielding) paint. Without arguing the efficacy of shielding paint, I find it curious that you would only paint the ceiling to shield cellular phone signals. Cel signals are emitted from relative low-height towers that generally radiate outwards. In fact, most sources of emf are emitted from close proximity to the earth's surface. Shielding the ceiling would only provide a barrier from emissions from satellites, aircraft, etc.
Two 2 pole 20amp breakers with just white wires connected to them. elec_2014 Electrical 36 11-01-2014 04:13 PM
door bell help wkd Electrical 13 07-09-2013 07:18 AM
Advantage of Aluminum vs Copper wiring in power tools ptsbob Tools 5 03-28-2012 09:02 AM
Power strip hack salex Electrical 3 01-31-2012 06:10 AM
Power washing aluminum siding bobtheblindguy Building & Construction 7 05-07-2011 09:04 PM
