Is Aluminum Tape Around Power Cables For EMF Reduction Unsafe? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree60Likes
Old 02-03-2017, 04:32 PM   #16
Rewards Points: 18
Re: Is aluminum tape around power cables for EMF reduction unsafe?
Originally Posted by jreagan View Post
My concern is heat. All wires get warm when current passes through them. That is basic physics. Cable is tested and rated to dissipate heat at a certain rate. You'll find the ratings, etc. stamped on the cable. You now have wrapped a thermal blanket around the cable with that metal insulating tape. The heat cannot get out. It is similar to the rule about not putting romex into conduit (except for short distances to protect the cable). If you are running high current loads through the cable (do you have any electric space heaters plugged into the circuits for example), the cable might get too warm. And if they are located in an exterior wall, it is already having to deal with the insulation in that wall. Just remember that cables like to "breathe"
Good point. Maybe I should remove the tape.
Thanks!!
Starglider is offline   Reply With Quote
Old 02-03-2017, 04:48 PM   #17
Usually Confused
lenaitch's Avatar
Rewards Points: 2,056
Perhaps the shielding should be tied into the silver ground installed in the zombie-apocalypse safe room.
Speedy Petey likes this.
lenaitch is offline   Reply With Quote
Old 02-03-2017, 04:51 PM   #18
Rewards Points: 18
Would this solve the overheating too?
Thanks!!
Old 02-03-2017, 05:39 PM   #19
Super Moderator
joed's Avatar
Rewards Points: 31,946
Metal duct tape , $6. Special tape installed by someone with a made up title $375.
Originally Posted by Starglider View Post
I came in fully expecting these jokes 👍😂
Thanks!!
It's no joke. It is a fact.
The Following User Says Thank You to joed For This Useful Post:
Starglider (02-03-2017)
Old 02-03-2017, 05:47 PM   #20
Rewards Points: 18
Cool.
Thanks!!
Old 02-03-2017, 06:28 PM   #21
Rewards Points: 680
The romex is now quazi MC cable, the metallic quality will act as a heat sink and help dissipate heat from the NM cable, so no problem there. And for sure there's no electric heater on the circuit, that's otherwise known as an EMF"death ray" machine!
LawnGuyLandSparky is offline   Reply With Quote
The Following User Says Thank You to LawnGuyLandSparky For This Useful Post:
Old 02-03-2017, 06:30 PM   #22
Rewards Points: 18
So you're saying it's good?
Thanks!!
Old 02-03-2017, 06:54 PM   #23
Rewards Points: 18
Please note there is no insulation in this interior wall.
Old 02-03-2017, 06:59 PM   #24
Rewards Points: 18
Originally Posted by Oso954 View Post
Just what metal tape (mfg and model #) did they use ?
This is the tape: https://www.uline.com/Product/Detail...B&gclsrc=aw.ds
Seems there is some disagreement in this forum as to whether this is safe or not.
Old 02-03-2017, 07:48 PM   #25
Master Electrician
Rewards Points: 5,374
I sure would like to se some empirical data on the efficacy of such an installation.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Speedy Petey (02-03-2017)
Old 02-03-2017, 07:54 PM   #26
Rewards Points: 18
That's for another thread (a million of which are already out there)
Thanks!!
Old 02-03-2017, 09:00 PM   #27
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Thanks!!
A million huh? Care to link to a few?
"Building biologist".
It's good that you came here expecting jokes, because the whole thing IS a joke. I bet you are "gluten intolerant" as well?
brric likes this.
Old 02-03-2017, 09:18 PM   #28
Rewards Points: 18
No but I am annoying person intolerant.
Thanks!!
LawnGuyLandSparky likes this.
Old 02-04-2017, 12:23 AM   #29
Rewards Points: 80
Clearly installed by someone who doesn't have much knowledge about emf, rf or wave propagation.......
If you were really worried I would have lined the walls with the tape instead of the wires. It would have been more effective. Especially he outer walls, turning your house into a faraday cage. And no, your cell phones wouldn't work anymore.
Although I offer this suggestion, I think it's far fetched..... I live at the end of a runway of a major international airport. I don't worry about stray emf...
Cheers!
supers05 is offline   Reply With Quote
The Following User Says Thank You to supers05 For This Useful Post:
Starglider (02-04-2017)
Old 02-04-2017, 04:49 AM   #30
dmxtothemax's Avatar
Rewards Points: 7,852
I would think any electrical inspector seeing such a set up would not like it at all ! Because you have modified the way the electrical cables are used. This could then Lead to insurance issues. It is simply risky because it is untested and possibly against code as your using cables in ways not approved by the cable makers.
GrayHair and Starglider like this.
dmxtothemax is offline   Reply With Quote
Two 2 pole 20amp breakers with just white wires connected to them. elec_2014 Electrical 36 11-01-2014 04:13 PM
door bell help wkd Electrical 13 07-09-2013 07:18 AM
Advantage of Aluminum vs Copper wiring in power tools ptsbob Tools 5 03-28-2012 09:02 AM
Power strip hack salex Electrical 3 01-31-2012 06:10 AM
Power washing aluminum siding bobtheblindguy Building & Construction 7 05-07-2011 09:04 PM
