Air Fryer Burnt Outlet - Electrical - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By curiousB
Old 08-13-2018, 06:46 PM   #1
Rewards Points: 36
Air Fryer burnt outlet
Hello everyone,
I have an air fryer in my kitchen, and the other day I was using it and I heard a pop and everything on the countertop went out. I went to check the breaker it was off and I could turn it back on but that outlet was toast. I opened up the outlet and look at the picture below .... My question is can I use electric tape over the part over the burnt part of the cable and just replace the outlet... I went to lowes the other night to get another outlet and the guy told me I needed to verify what amp is the breaker on that outlet....
I change this outlet some time ago and didn't know about checking the amps at the breaker so I may have put the wrong amp outlet there the last time I replaced it. So my question and concerns are can I cover the burnt parts of the cable in the wall with a heavy grade electric tape? the breaker this outlet is on is 20 ... If I change this out with a new outlet I assume I have to stop using the air fryer at this outlet? Any suggestion on location I can put the air fryer
BEN1122 is offline   Reply With Quote
Old 08-13-2018, 07:16 PM   #2
Rewards Points: 574
Re: Air Fryer burnt outlet
Post one more time so the pic will load. What is the nameplate amp rating on the appliance ?
Disclaimer: Any of my replies, advice, product recommendations, or projects that I have done that I post on this forum, are just for informational purposes only. Any reader choosing to use my postings, advice, product recommendations, or choose to duplicate any of my projects for their own use...are doing so at their own risk.
Gregsoldtruck79 is offline   Reply With Quote
Old 08-13-2018, 07:22 PM   #3
retired framer
Rewards Points: 14,142
You should be able to loosen the clamp at the back and pull a little more cable into the outlet box.
Old 08-13-2018, 07:23 PM   #4
Rewards Points: 17,812
Where the wires back stabbed into the outlet instead of around the screws?
Even if the wires where under the screws one loose connection can cause this.
Old 08-13-2018, 07:33 PM   #5
Rewards Points: 36
Ok I think I got the pics attached right this time sorry about that
Air Fryer burnt outlet-20180721_101852.jpg   Air Fryer burnt outlet-20180721_101919.jpg   Air Fryer burnt outlet-20180721_101925.jpg
Old 08-13-2018, 07:39 PM   #6
I'm seeing wires not totaly under the screws, to much insulation was striped off the wires.
There a strip gauge on the back side of the outlet.
If that's a metal box that can cause a short.
Old 08-13-2018, 07:43 PM   #7
Rewards Points: 36
The sticker on the air fryer @Gregsoldtruck79
Old 08-13-2018, 07:45 PM   #8
Rewards Points: 36
Do you think I should try to replace the box? Also if I cut the wire to shorten it a bit so only copper is under the screws what about the burnt cable should I wrap that with electric tape?
Old 08-13-2018, 07:50 PM   #9
retired framer
A pig tail is a short piece of wire from a wire nut in the box to the outlet
That can be added to your wire if it is to short to reach the outlet. Just join the two blacks to a black pigtail and the two whites to a white pigtail.
CodeMatters likes this.
Old 08-13-2018, 08:59 PM   #10
Rewards Points: 1,234
Were the screws tight on the copper wire? A loose connection will heat up under a higher load and could explain some of this. 20A won’t flow well through a barely snug screw.
CaptTom likes this.
curiousB is offline   Reply With Quote
Old 08-13-2018, 09:08 PM   #11
CodeMatters's Avatar
Rewards Points: 6,152
1750W is very high load for a 5-15P plug. If it doesn't fit tightly, due to
either a loose receptacle or worn plug, heat will build up excessively.
CodeMatters is offline   Reply With Quote
Old 08-14-2018, 02:15 AM   #12
dmxtothemax's Avatar
Rewards Points: 7,318
I would just cut out the damaged section,
And run a pig tail to the outlet.
That is a large load for any outlet,
So the outlet needs to be in tip top shape
Or even better still a good quality heavy duty outlet.
It may need it's own circuit or at least
a circuit with very little else on it.
You will be pulling around 15A.
dmxtothemax is offline   Reply With Quote
Old 08-14-2018, 04:37 AM   #13
Rewards Points: 574
The metal wall box has a bare equipment grounding conductor in the Romex cable and I see no ground wire on the receptacle's green grounding screw.
The box should be grounded with the bare ground wire with a ground wire pigtail from it, going to the receptacle.
And with a 14.6 amp load from that appliance, IMO it should not be on a 15 amp rated receptacle. I would install a 20 amp rated duplex receptacle.
Tags
kitchen outlet
Electrical Outlet Wired Wrong? cazeus Electrical 4 03-26-2018 07:23 AM
Multiple Outlets and One Switch Stopped Working Mullet Electrical 13 12-20-2017 09:37 PM
Trouble with Outlet Startingover Electrical 18 12-17-2017 03:40 PM
Outlet has more than 1 breaker linked to it... Mark C Electrical 13 05-28-2013 08:18 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
