Air Compressor Became Noisy - Trips Breaker - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joed
Old 05-26-2016, 06:57 AM   #1
Rewards Points: 8
Help. Please.
Suddenly, and without prior issues (except that tank had slow pressure leak, but no audible air discharge), the motor (Coleman Powermate 5HP/27 Gal. Model #200-2231) became noisy, runs rough and trips circuit breaker after 15 - 20 seconds or so.
I removed the cylinder head. Cylinder sleeve has no scratches and piston appears intact. If this were a car engine I would describe the sound as if there was a misfiring cylinder (knocking).
I should add that this compressor has had very little use over 10+ years of ownership, has never before tripped the breaker and there is no other load on the circuit.
This is the limit of my ability to deal with problem. Any and all comments (except on my ignorance) are greatly appreciated.
Howtodo? is offline   Reply With Quote
Old 05-26-2016, 07:48 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 32,378
Re: Air Compressor Became Noisy - Trips Breaker
Does the motor run fine with the belt off?
How does the compressor feel when turned by hand? Is there slack when rotated back and forth? Is there oil in the compressor?
J. V. likes this.
Old 05-26-2016, 08:33 AM   #3
randyhenke's Avatar
By noisy do you mean the motor hums or do you mean it's sounds like a bad bearing?
Sent from my XT1097 using Tapatalk
randyhenke is offline   Reply With Quote
Old 05-26-2016, 11:59 AM   #4
Rewards Points: 8
Thank you, joed ~ This model is direct drive and maintenance free.
Old 05-26-2016, 12:05 PM   #5
Rewards Points: 8
[QUOTE=randyhenke;3315305]By noisy do you mean the motor hums or do you mean it's sounds like a bad bearing?
Thank you, randyhenke ~ Given this choice, I would describe the sound as bad bearing. The motor turns and 'knocks' rhythmically until it trips the breaker. It is rated @15 amps and is on a 20 amp circuit so electrical supply is not the issue.
If it is a bad bearing, would the piston have 'scored' the piston sleeve?
Old 05-26-2016, 01:04 PM   #6
Super Moderator
joed's Avatar
Bearings usually whine or growl when bad. Knocking would send me toward a bad connecting rod or valve.
Old 05-26-2016, 02:12 PM   #7
randyhenke's Avatar
Agree
Old 05-26-2016, 05:03 PM   #8
Rewards Points: 8
[QUOTE=randyhenke;3316137]Agree
My sincere thanks to both of you for your kind responses.
Any advice on where to find instruction for troubleshooting bad connecting rod or valve?
HTD?
Old 05-26-2016, 05:31 PM   #9
Oso954's Avatar
Rewards Points: 2,124
There is an eccentric hub on the motor shaft. There is either a bearing or bushing on it that the connecting rod attaches to.
I would look at the rod to bushing or the bushing to hub connections for excessive play.
Oso954 is offline   Reply With Quote
Old 05-26-2016, 06:24 PM   #10
Rewards Points: 375
It's almost certainly a rod. I had one of those pumps literally explode and send shrapnel all over my garage. Was standing right next to it; explosion went to either side of me and missed me altogether. I did, however have to change my pants.
Here is the parts manual for it:
http://www.arkansas-ope.com/2002231C.pdf
Those oilless compressors are notorious for tossing rod bearings. Most times they are just throwaways. If it's fairly new and the receiver is worth it (large enough to warrant), you might retrofit another, or a better/different compressor pump to the tank.
al_smelter is offline   Reply With Quote
Old 05-26-2016, 08:27 PM   #11
randyhenke's Avatar
Drain your oil and use a coffee filter to run the oil through if you see metal flakes/shavings you know something's bad and it's time to look for a rebuild kit.
Tags
diy advice , tools
Touching ground wire to metal box trips breaker lmm Electrical 30 07-23-2014 12:36 PM
Microwave oven trips breaker Jimbo65 Electrical 28 12-14-2011 08:21 PM
Update: Power on several circuits comes and goes all at once, never trips breaker Michael H Electrical 9 07-03-2009 10:12 PM
20 Amp Breaker only trips once in a while panhandlion Electrical 14 11-26-2007 08:36 PM
Main Breaker Trips Repeatedly kkf Electrical 7 06-18-2007 04:31 PM
