Air Compressor - Electrical - DIY Chatroom Home Improvement Forum
Old 08-13-2009, 07:05 PM   #1
Air compressor
ok guys and gals.
I have a question. I just moved and I have a Craftsman Professional (60 gallon) 220v 15amp Air Compressor that I need to hook up asap. The wire running to the garage is 12/3WG and all it is running is the lights in the garage.
Can I splice my air compressor in there, I am really short on cash so running new wire is out of the question, and just swap the breaker out for a double pole 30amp and still leave the lights running as they are now?
dksob81 is offline   Reply With Quote
Old 08-13-2009, 07:21 PM   #2
Rewards Points: 150
Wink
johnnyboy is offline   Reply With Quote
Old 08-13-2009, 07:31 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Joe,
Is this a different house from the post last year?
http://www.diychatroom.com/f18/220v-breaker-27365/
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-13-2009, 07:53 PM   #4
yes it is
Old 08-13-2009, 10:06 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Is it for 3 way switches controlling the lights ??
You cannot put lights on a 30 amp breaker. Why are you suggesting 30 amps??
If the compressor is 15 amp cord and plug and 230 volts then you would need a double pole 20 amp breaker for the 12/3 if it isn't used for a 3 way switch at 120 volts.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-14-2009, 06:37 AM   #6
because I already have a 30amp double pole breaker. I am trying to do this as cheaply as possible, there is already 12/3 wire runnning to the garage and all the lights are wired to it. What do you mean by 3 way switcdh. I'm sorry I don't know a whole lot about this stuff.
Old 08-14-2009, 09:03 AM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Originally Posted by dksob81 View Post
because I already have a 30amp double pole breaker. I am trying to do this as cheaply as possible, there is already 12/3 wire runnning to the garage and all the lights are wired to it. What do you mean by 3 way switch. I'm sorry I don't know a whole lot about this stuff.
Are the lights controlled by two switches at different locations?
Stubbie
Old 08-14-2009, 05:58 PM   #8
no it just has 1 light switch
Old 08-14-2009, 06:19 PM   #9
Rewards Points: 2,398
Lights still being an unresolved issue, you shound not put 12 gauge wire on a 30 amp breaker; need a 20 amp max for that gauge. Still have to sort out what this wire and lights are doing.
bob22 is online now   Reply With Quote
Old 08-14-2009, 06:54 PM   #10
UAW SKILLED TRADES
Stubbie's Avatar
Ok I think maybe what you have is 12/2 with ground and you are calling it 12/3. Is it a black, white and bare wire (12/2G) or is it black, red,white and bare (12/3G)? Or if you can read the writing on the cable sheath that would clarify it.
Stubbie
Old 08-15-2009, 06:55 AM   #11
the sheathing says FTF (hard to read the 1st 3 letters) CORTEX 600v 12/3, the wires are RED, BLACK and BARE.
As for the breaker I can get a 20amp - thats no problem. but do you think it will work running it like this.
Old 08-15-2009, 08:45 AM   #12
UAW SKILLED TRADES
Stubbie's Avatar
Nope...unfortunately you only have 2 current carriers and a ground... if your running lights with that it's the wrong cable or you are not in the USA because the colors are wrong. Should be black, white and bare.
At any rate you cannot run a 220 volt compressor and a 120 volt light circuit on a 2 conductor with ground cable.
Stubbie
Old 08-15-2009, 12:36 PM   #13
" Euro " electrician
frenchelectrican's Avatar
The whole key issue there is a attached or deatached garage that will make the diffrence there.
If this garage is attached then it will useally not a issue to run new circuit however if this is a deatached garage now that will get pretty picky The NEC code in USA only allowed one multiwire branch circuit run into detached garage so you will need to change the cable or conduit with conductor size up and add a subpanel to detached garage.
Costwise that something I really can't comment due large variations on price depending on the area and brand name of breakers and how big you want to install the subpanel in.
If you want to go that route one of members in this forum will be more than happy to steer you in right driection.
Oh yeah it will be nice if you stated your location it will make it easier to depcher the NEC or CEC { Canada Electrical Code }
Merci,Marc
Old 08-16-2009, 12:35 AM   #14
I live in the US, Pennsylvania to be exact
Old 08-16-2009, 01:17 AM   #15
UAW SKILLED TRADES
Stubbie's Avatar
Then you can't do it with the wires you have. You need 4 wires to do both a 240 volt air compressor and 120 volt lights. 2 hots, a neutral and a ground. sorry but no way around it.
Stubbie
240v Air Compressor to 120v help ruacoltsnut General DIY Discussions 10 11-11-2010 04:05 PM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Compressor Replacement Lawrence Coppar HVAC 1 06-30-2009 10:50 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 01:10 PM
