AFCI Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 08:25 PM   #1
Rewards Points: 726
AFCI breakers
right now I have a standard GE residential breaker panel.. put in 1996... With dividing a few larger rooms and having to run new circuits for them and our code "requires" AFCI on all new runs... at least thats what the local code inspectors are telling us... which I guess isn't a bad thing to have AFCI, but do I need a new panel for this? or can I put AFCI in my current panel? Am I right that all that is different between the installation of an AFCI and a normal breaker is just the wire that has to be connected to the neutral bus bar?
BlueBSH is offline   Reply With Quote
Old 01-09-2010, 08:29 PM   #2
An AFCI will fit in your panel
They connect just like a GFCI breaker
Circuit neutral goes to the breaker, breaker white coiled pigtail goes to the neutral bar
Old 01-09-2010, 09:00 PM   #3
Thumbs up
It will fit. But the new (er), Combination AFCIs will not work if you have a Grounded Neutral on the circuit. There is a way to test for that. With a GFI Breaker. And if you do. Then you'll need tons of patience. till you eliminate the Ground/ed Neutral. !
spark plug is offline   Reply With Quote
Old 01-09-2010, 09:00 PM   #4
300zx's Avatar
Post
Here is a link to GE AFCI http://www.geindustrial.com/cwc/Disp...36&id=cb-qafci
300zx is offline   Reply With Quote
AFCI and 3-wire circuits...ugghh mhops Electrical 11 03-17-2010 11:22 AM
code question - AFCI / GFCI breakers Red Squirrel Electrical 15 09-17-2009 11:16 AM
AFCI Breakers Keep Tripping mopowers Electrical 12 09-04-2009 03:11 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 07:21 PM
