AFCI Breaker Won't Reset. Help Me Troubleshoot. - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 06-07-2010, 05:35 PM   #46
Learning by Doing
Leah Frances's Avatar
Here's the breakdown:
1. New AFCI breaker working for several days with light and recs working.
2. Cut power re-connected ceiling fan.
3. breaker continues to work until husband adjusts speed with remote. Breaker goes.
4. Disconnect ceiling fan - breaker holds until I turn on a light switch for another light on circuit.
5. Pull fan - replace with new fan - breaker holds until I turn on light switch.
6. WTF?
Relevant facts:
1. Pulled switch that controls the light fixture that has been causing breaker to throw - no visible problem.
2. Pulled light fixture - all connections seem good.
Please help, I'm feeling like an idiot.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-07-2010, 05:38 PM   #47
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
Sounds to me you may have a neutral issue and not a arc fault issue. A single pole arc fault requires a dedicated neutral like a gfci and if you tap off that neutral to feed something on another circuit or use it as a MWBC you will have this problem.
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 06-07-2010, 05:48 PM   #48
Learning by Doing
Here's the next set of facts:
1. Pulled new fan
2. Circuit holds with load (box fan in rec) - this tells me I have some problem with the part of the circuit that includes the fan? Right?
3. Breaker blows when light fixture is switched on. - So, should I replace the switch?
Old 06-07-2010, 05:49 PM   #49
Learning by Doing
So what would the neutral problem be? This is NOT a MWBC nor has it been used for any other circuit.
Old 06-07-2010, 05:53 PM   #50
Sparkaholic
Rewards Points: 150
When the arc fault trips does the light go out? Not the light on the fan the light that trips the arc fault when turned on?
Old 06-07-2010, 07:13 PM   #51
Learning by Doing
Here's the sequence with fan disconnected.
- breaker on
- switch light on
- light comes on - for a fraction of a second - breaker trips.
With light switch in the 'on' position breaker will not reset. With the light 'off' breaker will re-set.
Old 06-07-2010, 07:35 PM   #52
Master Electrician
Rewards Points: 5,082
If you remove the fixture and wire nut the wires in the j-box (isolate them) does throwing the switch still trip the breaker?
brric is offline   Reply With Quote
Old 06-07-2010, 07:51 PM   #53
Learning by Doing
Ok, I'm a bit slow so may I double check your suggestion:
1. Remove the fixture and wire nut the wires in the jbox - do you mean in the box for the light?
I'll be trying this in the AM. Was up to 2am last night helping my Dear Husband re-configure his stereo system (he's taking his board exams on thursday and he's a might be jumpy). Trying to chill out tonight. Watching HBOs Band of Brothers. Good stuff.
Old 06-07-2010, 08:01 PM   #54
Master Electrician
Remove the fixture so that nothing is attached to the wires in the j-box in the ceiling and try the switch. If the circuit holds the problem is within the fixture.
Old 06-07-2010, 08:05 PM   #55
Learning by Doing
I'll give it a try. Thanks.
Old 06-08-2010, 10:50 AM   #56
So the new AFCI has changed no symptoms? What make and model is it?
Old 07-08-2010, 03:47 PM   #57
Learning by Doing
WOW - it's been a month since I looked at this
OK folks -
Today I monkeyed around with this and I'm completely stumped.
today's results:
A. Disconnected ceiling fan - for the meanwhile it's out of the picture.
B. Disconnected light fixture and nutted it off (tee-hee)
1. Breaker holds when switch thrown
2. box fan connected to rec associated with the circuit runs
C. Reconnect light fixture/ box fan still plugged in
1. breaker switches off when light fixture switch flipped.
D. I pulled the light fixture and wired in a replacement light (just wire and bulb holder)/ box fan plugged in
1. flipping switch throws breaker.
E. With box fan removed/ test light connected
1. Breaker holds
2. Plugged in my power inverter for my computer
a. breaker holds
3. Plug in box fan
a. breaker fails
So WTF!!!! I thought it was the light fixture, but it seems to be a load problem. What's going on.
HELP. I promise I won't wait a month to try and fix it.
Old 07-08-2010, 04:00 PM   #58
Learning by Doing
F. Replaced light fixture
1. breaker fails immediately when switch is thrown.
~ I've pulled the light fixture apart and checked the obvious connections.
G. Pulled light fixture and nutted it off.
1. Circuit fails with box fan
2. circuit holds with power inverter.
:confused:
Old 07-08-2010, 04:07 PM   #59
Learning by Doing
Last detail. Fan works on other circuit.
Old 07-08-2010, 07:30 PM   #60
Need some clarification. . .
aa
bb
cc
Breaker holds
dd
Plug in box fan
breaker fails
ee
ff
gg
hh
aa box fan only = no problem
bb box fan + this light = problem
1Siemens said you need an arc + a minimum current draw to trip the AFCI
cc box fan + replacement light = problem
See 1 above
dd test light + no box fan = no problem
2 what wattage test lamp?
ee box fan (+ test light?) = problem
see 1 above
ff replacement light (+ box fan?) = problem
see 1 above
gg box fan (+replacement light?) = problem
see 1 above
hh Non AFCI circuit?
AFCI circuit breaker bryan1282 Electrical 14 02-11-2010 06:06 PM
breaker won't reset wendl Electrical 3 01-15-2010 10:03 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
Breaker tripped and won"t reset princessme Electrical 8 01-19-2009 07:10 AM
