Advice: Need Alarm For GFCI In Basement - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 09:37 PM   #46
Just call me Andrew
Rewards Points: 1,032
Originally Posted by Scuba_Dave View Post
Or wire up an outlet (where you will see it) & plug in an LED nightlite that is always on - bathroom maybe ?
This would be against code to put in a bathroom, right? Since the circuit would also have a non-bathroom outlet.
Andrew
secutanudu is offline   Reply With Quote
Old 05-02-2010, 09:56 PM   #47
As long as its GFCI you can have a 2nd outlet/circuit
You need at least (1) 20a circuit feeding the bathroom
As far as I know a 2nd circuit is not against the code
Many large/fancy bathrooms w/TV's etc have more then 1 circuit
My bathroom has 4 different circuits
Old 05-03-2010, 06:33 AM   #48
Just call me Andrew
Oh, OK. Got it, dave!
Andrew
Old 05-03-2010, 11:09 AM   #49
Thumbs up
I think I'd wire a small indicator light somewhere where I would see it on a daily basis
If the lights out, the circuit is out
I may actually do this with the circuit for our freezer
Or the alarm could be wired to a NC (Normally closed) or SPDT (Single Pole Double Throw) relay with the contacts closing when the circuit is losing energy.!
spark plug is offline   Reply With Quote
Old 05-05-2010, 06:58 PM   #50
Rewards Points: 151
Originally Posted by andrew79 View Post
two things that perhaps are worth pointing out.
wether the circuit is gfci protected or not if the basement floods it's still going to trip out
Secondly....in my experience a freezer should hold food without power for at least 6hours or so minimum especially when it's not being opened constantly....so why the need for something that will wake you up out of a dead sleep?
Because the alarm I have on there has a battery that will only last 6 hours before dying out. And that's the spec. I don't think it's that long.
tgm1024 is offline   Reply With Quote
Old 05-05-2010, 07:08 PM   #51
Rewards Points: 151
Originally Posted by VelvetFoot View Post
How 'bout the oil burner in the basement?
My place is not too old but I'm pretty sure it's not on a GFCI.
There already is a non-GFCI outlet (above the water softener). It's also powering the sump-pump in the floor. (Thank goodness it's there by the way----I've been told that such pumps are notorious for throwing GFCI's open).
I think that someone unnamed may just accidentally install an extension to that circuit across the ceiling and be done with it.
Old 05-05-2010, 07:52 PM   #52
Thumbs up
I have to relate a funny, funny story that happened during a service call. Even though the Blog Administrator (the Hon. MR. Nathan W.) is not running a contest at this time. I was called to re-hang a chandelier that landed on the dining room table. Upon entering the apartment, the Lady of the house starts out by telling me that they.... "Didn't do anything..." did not twist the chandelier..., were not the cause of it landing where it did...! My response; "I'm not the Police or the District Attorney". I don't care who did what. Or anything. Or nothing at all. My job is to hang the Chandelier to the ceiling box...And make it stay there...! (Btw. the reason it landed on the table --regardless of who did or did not twist it-- is, because the original installer did not use locknuts on the 3/8" nipple to prevent the Chandelier from twisting and falling.!
Last edited by spark plug; 05-05-2010 at 07:53 PM. Reason: Typographical error (Typo)
Old 05-06-2010, 09:07 AM   #53
Rewards Points: 151
Were there regular nuts [still] there, or was the thing somehow just held up by wire?
Old 05-06-2010, 11:24 AM   #54
Thumbs up
There was a standard crossbar with a 3/8" "Opening" through which a 3/8" nipple was threaded. The ceiling box, a "Doughnut" was (firmly) fastened to the structural beam. (Btw. There was no damage to the (heavy) fixture or the table). I installed (and tightened, real tight.) Two locknuts. One above and one below the crossbar to prevent it from "Swinging".!
Last edited by spark plug; 05-06-2010 at 11:27 AM. Reason: failed to insert (Second) Parenthesis in sentence.
Tags
alarm , gfci
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Basement Bath advice... jfls45 Remodeling 4 06-09-2009 06:10 AM
Need advice on basement support column problem aibrean Building & Construction 9 06-08-2009 04:29 PM
Advice on basement shop wiring WoodworkerDave Electrical 4 04-05-2008 12:12 PM
