Advice: Need Alarm For GFCI In Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2010, 06:01 PM   #1
Rewards Points: 151
Advice: Need alarm for GFCI in basement
Freezer is plugged into GFCI outlet in basement. I have an alarm plugged into it (that contains a battery) but the sound doesn't last long and it's fairly anemic.
DOES there exist a GFCI outlet, or device to replace the GFCI recepticle itself, that will throw a loud alarm powered by the house current (pre-interrupt)?
Thanks! I lost a big freezer full of stuff by not being careful.
tgm1024 is offline   Reply With Quote
Old 04-24-2010, 06:40 PM   #2
Is it a dedicated circuit to the freezer ?
How old is the freezer ?
Why did it trip in the past ?
Old 04-24-2010, 07:16 PM   #3
Post a link to the alarm.
The second option: a SPDT relay [$3 from Hosfelt, or from Radio Shack] with 120 vac coil which goes to the freezer outlet. A turned-on radio or loud alarm is in series with the normally closed contacts and another source of 120v. When the coil drops out the contacts close and sound the alarm. The relay contacts have to be rated to carry the alarm current.
Old 04-24-2010, 07:29 PM   #4
Electrician
Rewards Points: 910
If this is dedicated to the freezer, if so does the NEC allow you to put a regular plug in. If it was me I would change it to a regular plug and then not have to worry about it tripping and looseing a freezer full of food.
darren is offline   Reply With Quote
Old 04-24-2010, 07:43 PM   #5
No they did away with that in 2008, has to be GFCI now
Old 04-24-2010, 09:25 PM   #6
Electrician
Rewards Points: 910
Thats dumb, if it was me i still would be putting a regular plug. I doubt it if the publishers of the NEC will come along with a cheque if my my GFI trips and I lose a freezer full of food.
But I'm not telling you to do that, keep it as a GFI
Old 04-25-2010, 08:58 AM   #7
Licensed electrician
Rewards Points: 3,662
I am sure the basis for the CEC as well as the NEC is life safety, not food safety.
A normally functioning freezer or refrigerator should not trip a GFI. If it trips it needs to be fixed or replaced.
Old 04-25-2010, 09:05 AM   #8
Electrician
Rewards Points: 910
But the CEC does not require all basement plugs to be GFI protected.
Old 04-25-2010, 09:17 AM   #9
Posters IP tracks to the US
Old 04-25-2010, 09:46 AM   #10
Electrician
Rewards Points: 910
What happens if it is a finished basement do you still need a GFI or is just unfinshed basements that needs GFI.
Old 04-25-2010, 09:49 AM   #11
GFI protection is only needed in the unfinished portions. AFCI protection might then be then needed.
Old 04-25-2010, 09:52 AM   #12
Electrician
Rewards Points: 910
Thanks Jim thats good to know for future questions.
Old 04-25-2010, 10:02 PM   #13
Rewards Points: 151
It's tripped recently by having the water rise enough to reach the end of the extension cord I had connected to a fan.
But even so, I still am not a fan of just leaving this thing be. I've had GFCI's trip by just turning on something with a motor. Valid or invalid reasons, I don't want to lose that much food again.
Old 04-25-2010, 10:12 PM   #14
Sorry to see that a freezer of food is more important than someones life.
Old 04-25-2010, 10:14 PM   #15
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
are you sure? I'm thinking dedicated receptacles for appliances do not have to be GFCI.
same with AFCI I think
and as he turns to grab his 08 NEC, he realizes he has no idea where it is so he can check for himself
Tags
alarm , gfci
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Basement Bath advice... jfls45 Remodeling 4 06-09-2009 06:10 AM
Need advice on basement support column problem aibrean Building & Construction 9 06-08-2009 04:29 PM
Advice on basement shop wiring WoodworkerDave Electrical 4 04-05-2008 12:12 PM
