Ademco 40P Comm Error - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2009, 09:36 AM   #1
Chicago, IL
Michael Thomas's Avatar
Ademco 40P comm error
A few years back I self installed a system based on a ADEMCO 40P panel.
Everything has been working fine until recently, when the system was powered down for a few hours.
It came back uo OK, functional and with all programming apparently intact, except that now every night about 1:00AM I get an alarm and the error message "comm error". Very annoying!
This system is not and has never been wired to any sort of communications line or device.
Suggestions?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-06-2009, 04:02 PM   #2
Rewards Points: 150
Try going into program mode, and then out again. This will reset the system, without powering it down. Somewhere in programming you may also have something set to transmit troubles, which is what it is trying to do. Or, if it happens at the same time every day, it could be set to send a test signal on a 24 hr. interval, which is at 1:00AM, and when it fails, it trips the comm error. Check your programming fields.
TJ_in_IL is offline   Reply With Quote
"interface failure/miswire" Vapor error? windowguy Plumbing 0 05-17-2009 04:59 PM
Carrier Furnace Error Code 33 s6skuzy01 HVAC 9 03-09-2009 11:42 AM
Brand new PAYNE PG9MAB won't start . Error code 12 tp618 HVAC 3 12-19-2008 09:21 PM
trane furnace with inducer blower error tjh57 HVAC 1 10-22-2006 07:45 PM
