Adding Separate Ground Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2010, 10:11 PM   #1
I have a 2-prong outlet that i replaced with a 3-prong outlet. As you probably guessed there is no ground attached because there is only the two wire romex. I checked the outlet box and it is not grounded. I am wanting to purchase a new flat panel tv. I would like the outlet to be properly grounded before i plug in my investment. My big question is. Is it ok to run a separate ground wire from that outlet back to the service panel? I plan on using 14 awg solid wire.
scrubby18436572 is offline   Reply With Quote
Old 04-22-2010, 10:22 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 24,038
If you can run the single wire why not run a new cable?
Old 04-22-2010, 10:26 PM   #3
It is easier for me to run one ground wire than a new circuit. I have a basement with drywall ceilings. You cant get to anything. One other problem is the outlet that im wanting to ground is in the middle of a circuit. The outlet is tapped on the bottom and continues to the next outlet off of the upper terminals. So im not sure where in the circuit that outlet is. Oh yeah and the last issue is that my service panel is full. A few years ago when we replaced the 100 amp panel we bought tandem breakers. After mounting the panel we realized that they wouldnt fit the box we just installed.
Old 04-22-2010, 10:46 PM   #4
Is it a 15a circuit ?
If so #14 back to the panel is fine
Old 04-22-2010, 10:57 PM   #5
Scuba, The circuit is on a 20amp breaker. Will that work or should i use 12 awg wire?
Old 04-23-2010, 12:48 AM   #6
For a 20Amp Circuit, #12, for 15Amp, #14.
House2488 is offline   Reply With Quote
Old 04-23-2010, 06:13 AM   #7
Just call me Andrew
Rewards Points: 1,032
You can't downsize ground wires until you get to higher amperage circuits. House2488 is correct.
Andrew
secutanudu is offline   Reply With Quote
Old 04-23-2010, 10:27 AM   #8
Super Moderator
joed's Avatar
What size wire is on the circuit? Ungrounded wires were most often #14. That circuit could be over fused.
Old 04-23-2010, 10:49 AM   #9
It is 12 awg 2-wire
Old 04-23-2010, 07:36 PM   #10
Yes, so you would use a #12 Green ground wire.
neutral wire became ground? okedomantakeshi Electrical 18 12-29-2009 03:18 AM
Running a ground wire T Blanco Electrical 3 01-07-2008 03:17 PM
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 08:23 AM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
