Adding A Second Ground Bar To Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 10:04 AM   #1
Adding a second ground bar to subpanel
I have subpanel with 12 open spaces, but the ground bar only has room for 10. I don't think it's permissible to double up 2 ground wires into one space on the bar, correct? If i add a second ground bar, do I need to run a copper jumper between the existing ground bar and the new one?
thanks
robbinsrace is offline   Reply With Quote
Old 09-23-2010, 10:14 AM   #2
Just call me Andrew
Rewards Points: 1,032
You can double up 12AWG or 14AWG ground wires under 1 screw, but only if the wires are the same size.
Andrew
secutanudu is offline   Reply With Quote
Old 09-23-2010, 11:29 AM   #3
You CANNOT double lug (two wires under one screw) unless the panel manufacture states that you can in their documentation. Alot of manufactures you can but you need to make sure.
If you're talking about needing one or two more... why not just wire nut two circuits and one output wire and then use the output wire to the actual ground bus bar? That is if you're in the US. If you're Canadian thatís a no no.
DownRiverGuy is offline   Reply With Quote
Old 09-23-2010, 11:32 AM   #4
Just call me Andrew
This is legal in the US? I'm not saying it isn't, I just have never heard that suggested by anyone here.
Andrew
Old 09-23-2010, 11:36 AM   #5
Ideal solution... no. but there is nothing that says you can't do it. I wouldn't think twice about doing it. Now a neutral... eh I don't think I would because it wouldn't be uncommon to have a nice bit of current flow in there.
For MOST things you can consider a panelboard as a big junction box.
Canadian code actually does not allow this and states it verbatim in their code.
Old 09-23-2010, 12:14 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
I haven't seen a newer panel where you couldn't double or even triple up on ground wires of the same size. Meaning it is more than likely that you are fine doing so.
Old 09-23-2010, 12:31 PM   #7
Thanks for the help. The panel specifies tightening torque for up to 3 conductors on the ground bus, so I guess I'm ok with doubling a couple of spots. I had no idea this would be okay- thanks!
Greg
Old 09-23-2010, 12:38 PM   #8
" Euro " electrician
frenchelectrican's Avatar
I have no issue like that in USA side and with ground bar you can have 2 or 3 the same size conductor to one screw { hole } only with 2.5 or 4.0mm≤ { #14 or 12 AWG } conductors.
But for netural no it must have it own screw { hole } on the netural bussbar
Merci,
Marc
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 04:52 PM
How is this subpanel ground? FixingOlga Electrical 19 07-17-2008 08:31 AM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
