Adding Range Hood To 15A Light Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2016, 07:26 PM   #1
Rewards Points: 58
Adding range hood to 15A light circuit
We need to add a range hood to the kitchen.
The kitchen has a 15A dedicated circuit for lights. I traced everything that runs on it - and calculated the draw. The range hood is added in based on manufactures specs. Here is the breakdown:
Range hood fan 1.8 amps
Range hood lights 1.3 amps
Ceiling fan/light 1amp
Office outlet(phone charger and laptop) 2amps
Hanging Light fixture - 6x 40w bulbs 2.1 amps
Recessed kitchen lighting 7x 14 w LED bulbs 1 amp
Ceiling light fixture - pantry 3x 40w bulbs 1 amp
I assume I could even lessen the draw on some of the things by going to an LED bulb instead of an incandescent .
With everything at full draw it puts me at 10.2 amps. Any reason not to use this circuit for the range hood given the breakdown above? I assume I could even lessen the draw on some of the things by going to an LED bulb instead of an incandescent
dman535 is offline   Reply With Quote
Old 09-15-2016, 09:19 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 54
Re: Adding range hood to 15A light circuit
As long as the hood is hard wired you are fine.
My electrical answers are based on 2014 NEC, you may have local amendments.
Adding a new light and switch to existing circuit amwxx Electrical 7 03-15-2016 07:43 AM
Help with adding a new light circuit from an existing switch bank (three-way) sshanky Electrical 2 02-15-2016 01:17 AM
removing uv lighting and adding track light AlexanderGuy Electrical 2 08-12-2012 07:40 AM
Range Hood on Microwave Circuit - Legal? Thadius856 Electrical 18 08-11-2012 12:25 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
