Adding An Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2015, 01:09 AM   #1
Rewards Points: 225
adding an outlet
Want to add another outlet in a bedroom. Will not be running a new circuit for this outlet, run off the existing outlet circuit in the room. Do I need to check what else is on this line or since it is one outlet can run the new wire from the existing to the new outlet? If it needs to be checked first how could one determine if the additional outlet can be placed on the existing circuit? Thank you.
gt1935 is offline   Reply With Quote
Old 08-24-2015, 01:10 AM   #2
Rewards Points: 1,428
Do you have any outlets or switches nearby the place where you want to install a new outlet?
poiihy is offline   Reply With Quote
Old 08-24-2015, 12:27 PM   #3
Oso954's Avatar
Rewards Points: 1,964
What is the purpose of the new receptacle ? If it is just adding one for convenience it is one thing, if you are adding a significant load it is another.
It is a good idea to determine the limits of a circuit before adding to it. You can shut that circuit down, then check for the devices that do not have power.
Once you know everything that is on the circuit, you can either make a judgement call or add the wattage of everything on circuit. Don't forget to add temporary loads like vacuums or irons if they are ever plugged into that circuit.
If you are in Canada, you have a limit on the number of receptacles on a circuit.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Jim Port (08-24-2015)
Old 08-24-2015, 01:26 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 23,762
That limit is 12 and includes all receptacles lights and fans.
The Following User Says Thank You to joed For This Useful Post:
Oso954 (08-24-2015)
Old 08-24-2015, 09:39 PM   #5
Rewards Points: 225
existing outlet maybe 8 ft or so. going to check whats on the line first. thanks.
Old 08-24-2015, 09:40 PM   #6
Rewards Points: 225
Outlet is for convenience. will check to see whats on this circuit. thanks.
Old 08-26-2015, 10:27 AM   #7
Special User
Rewards Points: 1,230
If you're on the latest NEC code cycle, you cannot extend a circuit unless it is, or unless you upgrade it to, AFCI.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Adding an outlet to a bit of a mess... mikeyp78 Electrical 5 06-27-2014 02:11 PM
Adding new receptacles/ outlet federer Electrical 19 01-24-2013 03:14 PM
adding a switch to an outlet with two circuits jeffpeter Electrical 16 12-10-2012 08:38 PM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 12:53 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 07:59 PM
