Adding Outdoor Washer And Dryer - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 05-28-2019, 04:13 PM   #1
Rewards Points: 145
adding outdoor washer and dryer
I've read over the codes https://www.nfpa.org/NEC/About-the-N...58&access=open
But still have some questions.
I plan on adding one 20A 115vac breaker and one 30A 230vac breaker. Then running the wires in two conduits thru the block wall from inside garage to the outside. then securing to wet rated surface mount boxes, one each for the 115vac and the 230vac electrical socket receptacles.
The boxes and enclosed covers will be wet outdoor rated.
The receptacles will be GFCI.
I believe the codes said I needed a cutoff outside the house. Why?
When I read the codes a few years ago, I though I read mention of 4 prong required for the 230vac and I think there was also instructions on how to hook up a 4 conductor cord to the older 3 terminal dryers, but i cant find that now.
Any advice will be appreciated.
paul
paulmars is offline   Reply With Quote
Old 05-28-2019, 04:21 PM   #2
Rewards Points: 386
Re: adding outdoor washer and dryer
No cutoff needed - the cord & plug serve as cutoffs.
LawnGuyLandSparky is online now   Reply With Quote
Old 05-28-2019, 04:30 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 50
Dryer receptacle do not come as GFCI. And it is not required.
Sent from my Moto E (4) Plus using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 05-28-2019, 04:43 PM   #4
retired framer
Rewards Points: 64
Do not use flat bottom gables with scissor trusses.
Old 05-28-2019, 04:50 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 6
No GF protection required for an outdoor circuit? Or is that only a rule for general service circuits.
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
Old 05-28-2019, 04:55 PM   #6
retired framer
Rewards Points: 64
A GFCI would not work on a 3 wire dryer anyway.
Old 05-28-2019, 05:27 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 50
Basically yes, for 120 volt 15/20 amp circuits.
To the OP, for a new dryer circuit it must be 4 wire and use a 4 wire cord.
Sent from my RCT6213W22 using Tapatalk
lenaitch likes this.
Old 05-28-2019, 07:43 PM   #8
Rewards Points: 14
Outdoor washer and dryer?
I have never seen a washer and dryer approved for outdoor use.
Brushog is offline   Reply With Quote
Old 05-28-2019, 09:37 PM   #9
Rewards Points: 386
I assumes they were going into some kind of enclosure.
Old 05-30-2019, 08:10 PM   #10
Usually Confused
lenaitch's Avatar
Rewards Points: 6
Coming from a northern clime the concept of appliances outside or in garages seems so strange but I've seen enough threads on here about them I've stopped wondering.
Sic Itur at Astra
Old 05-31-2019, 02:13 PM   #11
Rewards Points: 58
Remember that they're is water within the washer hoses, etc. that will freeze in the winter even if the faucet is cut off.
Wiredindallas is online now   Reply With Quote
Old 05-31-2019, 03:22 PM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 50
Years ago I had a cabin in western Mass. that I shutdown for the winter. Drained all the pipes and used RV antifreeze in the traps and toilet. To winterize the clothes washer I removed the H/C supply lines and poured a quart of RV antifreeze into the drain hose. Never had an issue, connected it back up in the spring and ran an empty cycle to clean out the antifreeze.
Old 05-31-2019, 04:53 PM   #13
Rewards Points: 145
can I use one conduit for both?
or
Can I tap the 115 off of one side of the 230, like my stove does?
Old 05-31-2019, 06:18 PM   #14
A "Handy Husband"
rjniles's Avatar
Rewards Points: 50
or
No that won't fly, need 2 circuits. Or run a 40 amp circuit and use a small sub panel.
Old 05-31-2019, 08:42 PM   #15
Rewards Points: 145
anything else I need to know?
