Adding Lights With 12-2 Vs 14-2 - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 10:55 AM   #1
Rewards Points: 252
Adding lights with 12-2 vs 14-2
Is it against code to extend a branch of lights w/ 12-2 if it is a 15 amp circuit?
I just added 4 outlets in my garage using 12-2. I have a bunch of it left over and would like to add some lights as well to an existing 15amp light circuit. Do I need to go out and buy some 14-2, or can I use the 12-2?
Sorry if this has been covered before. I couldn't seem to find a thread that went over this.
mopowers is offline   Reply With Quote
Old 03-14-2010, 10:59 AM   #2
Master Electrician
Rewards Points: 5,082
Not a code issue but it could cause confusion in the future. Go for it.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
mopowers (03-14-2010)
Old 03-14-2010, 11:03 AM   #3
Back when a roll of 12-2 was $29 I used to use it for lights
Now I use 14-2 for 15a lighting circuits
As stated, there isn't any code problem with using 12-2 on a 15a circuit
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Old 03-14-2010, 11:29 AM   #4
Rewards Points: 252
Thanks guys! You just saved me some $$$
Adding recessed lights in basement tbone2004 Electrical 8 05-11-2011 10:19 AM
Adding two pole lights to garden. gante Landscaping & Lawn Care 2 02-22-2009 09:56 PM
Adding 4 Recessed Lights to single wire themayor Electrical 5 02-05-2009 04:08 PM
adding lights mharwell01 Electrical 1 01-03-2009 03:59 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
