Adding Ground Bar - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 10:28 AM   #1
Just call me Andrew
Rewards Points: 1,032
Adding ground bar
I have a 100-amp cutler-hammer CH panel. I want to add a subpanel, but the current panel is full. I plan to install 2 tandem breakers to make room for the new 60A breaker.
The share ground/neutral bar is full. It is on the right side.I'd like to add another to the left. How do I bond the two together? Can I just get 2 lugs and run a #6 bare copper from one to the other? Do I just install it with sheet metal screws to the back of the panel?
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 11-15-2011, 10:34 AM   #2
Master Electrician
SD515's Avatar
Rewards Points: 506
If it’s the main panel you’re adding the ground bar to, the current ground bar should be bonded to the panel already. Adding a grnd bar and screwing it directly to the panel, with the supplied screws, will bond it to the existing bar.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
secutanudu (11-15-2011)
Old 11-15-2011, 10:35 AM   #3
Just call me Andrew
Originally Posted by SD515 View Post
If itís the main panel youíre adding the ground bar to, the current ground bar should be bonded to the panel already. Adding a grnd bar and screwing it directly to the panel, with the supplied screws, will bond it to the existing bar.
Thanks, yes it is the main panel. I can verify this with a continuity tester after installing, right?
Andrew
Old 11-15-2011, 10:41 AM   #4
Master Electrician
SD515's Avatar
Rewards Points: 506
You can if you want. If you cont test the existing bar, you should find it’s bonded to the panel tub. FYI, the supplied screws will be machine screws…you don’t want to use sheet metal screws.
Kyle
Old 11-15-2011, 03:29 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 96
Instead of adding a ground bar, remove a number of ground wires, pigtail together and run the pigtail to a single hole. This will free up space on the existing bar.
My electrical answers are based on 2014 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Old 11-15-2011, 03:32 PM   #6
Just call me Andrew
Didn't know that was allowed. I guess as long as I use whatever the highest gauge wire in the pigtail is to connect to the bar.
Andrew
Old 11-15-2011, 04:07 PM   #7
This is fine to do so long as the largest size conductor is the size you use as a pigtail.
Colomboj is offline   Reply With Quote
Old 11-15-2011, 10:04 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 96
That is correct. I only pigtail same size grounds with same size pigtail. But you can chose to mix #12 and #14 with a #12 pigtail.
Old 12-12-2011, 09:01 PM   #9
Just call me Andrew
I just installed the ground bar on my new square-d homeline sub panel - it's a main breaker panel. i removed the bonding screw, so the factory installed neutral bbars are NOT grounded to the panel. THe new ground bar I installed does not show continuity between it and the panel (nor does the main bar). the two bars (factory-installed and the one I installed) do not show coninuity to each other.
Why does the ground bar i installed not show continuity to the panel? Is it because the metal frame of the panel is painted? I did verify the tester was working, which it is.
Andrew
Old 12-12-2011, 09:14 PM   #10
Is it your main panel or a sub panel? You've stated it as both. If its your main panel you must bond it. It also sounds like it is the paint insulating you from having your bus grounded.
Holy Funk is offline   Reply With Quote
Old 12-12-2011, 09:26 PM   #11
Master Electrician
Rewards Points: 5,140
You removed the bonding screw there should be no continuity.
brric is offline   Reply With Quote
Old 12-12-2011, 09:30 PM   #12
Super Moderator
joed's Avatar
Rewards Points: 29,578
Paint?
Old 12-12-2011, 09:31 PM   #13
Master Electrician
SD515's Avatar
Rewards Points: 506
There may be some paint in the threads of the new bar’s mounting hole causing the ‘no continuity’, but more likely you’d have to scratch the paint a bit to make contact with the tub itself with your meter probe. You can try this: Shut the sub-panels ‘main’ breaker off (de-energizing the main bus-bars), put one probe on the new bar and the other on the screw that retains the main breaker…it’s just below the main brkr but above the branch circuit brks 1 & 2, in the center. It’s also screwed into the tub. You should show continuity.
Kyle
Old 12-12-2011, 09:33 PM   #14
Master Electrician
SD515's Avatar
Rewards Points: 506
I believe he's looking for continuity between the new grnd bar and the tub.
Kyle
Old 12-12-2011, 09:42 PM   #15
Sparky
Rewards Points: 510
scratch the paint a bit with your tester
Techy is offline   Reply With Quote
Attach #4 Copper to Neutral/ Ground Lug Sierevello Electrical 3 01-29-2011 02:04 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 05:52 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
