Adding A Breaker To Main Lug Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-14-2011, 07:16 AM   #16
Rewards Points: 2,800
deleted
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 12-14-2011, 07:22 AM   #17
Originally Posted by kst43368 View Post
It may not be usable, but there is no question a Square D 20 amp breaker will attach and fit in that space. It's not a matter of the buss not extending that far or being unable to accept a breaker in that spot.
If you accidentally removed the twist out then you can put a breaker there to fill the hole in the cover (but it would not be energized). I don't see a stab in (upright fin) on the bus at that location. If you want to, you could unsnap the next breaker and compare the appearance of the bus bar underneath.
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 08:00 PM
Sub Panel Main Lug Load Center - Single Phase ? Roy Rowlett Electrical 21 08-20-2009 06:55 PM
Adding a sub panel 250ft away from the main z-man99 Electrical 4 07-19-2009 01:56 AM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 04:52 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
