Add New Exterior Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2015, 11:41 AM   #1
Rewards Points: 818
Add new exterior fixture
We want to add a new light above a side entrance by tapping into the front light and using the same switch to control both. Currently the siding is removed and it is under a covered porch.
We contemplated running it through rigid conduit, but don't like that idea. Do I have to run it through the attic/walls or is there a type of cable that can be run along the underside of the roof rafters/framing? Fwiw- we have exposed rafters as our finished ceiling.
cibula11 is offline   Reply With Quote
Old 07-13-2015, 12:06 PM   #2
Rewards Points: 2,600
liquid tight flex conduit maybe ??
concrete_joe is offline   Reply With Quote
Old 07-13-2015, 12:10 PM   #3
Rewards Points: 818
Can Romex be used, if not could the Romex be hidden with trim along the top of the ceiling ...I'm going to attempt it the normal way through the attic but fishing wire in this location may not work, so I want a plan B just in case
Old 07-13-2015, 12:16 PM   #4
if its open to the weather then its a wet location, so no, std NM romex cannot be used. however, i believe UF type of "romex" can be used there with a WP box. i believe there are "romex" type of clamps that have rubber inside so it "seals" when you clamp the wire (the inside has profile of romex shape, etc). or 1/2"npt to 1/2"F glue pvc fitting and then duct seal it.
all that said, your locale inspection dept can advise on what you can or connot do regardless of what NEC says, etc.
