Add Lights To A 3 Way Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2010, 02:45 PM   #1
Add lights to a 3 way circuit
I have a 3 way circuit set up this way:
Supply(2 wire) --> switch 1(3wire) --> light 1(3wire) --> switch 2(3wire)
I would like to add two more lights in the 3 wire run between switch 1 and switch 2. How do I connect them?
Brad
bfackrell is offline   Reply With Quote
Old 08-22-2010, 02:55 PM   #2
Electrical Contractor
kbsparky's Avatar
You have to run some 2-wire from light 1 to lights 2 and 3 in order for it to work.
You can't interrupt the 3-wire switch loop past the light.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
bfackrell (08-22-2010)
Old 08-22-2010, 03:37 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 23,968
Agree. The only way it will work is if you tap into the existing fixture. You can NOT cut into the three wire cable between the lights at any point other than the existing fixture.
The Following User Says Thank You to joed For This Useful Post:
bfackrell (08-29-2010)
Old 08-22-2010, 03:46 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
As Kbsparky said just add 14/2 at points 1 & 2 at the light fixture then run it to the new light boxes and fixtures.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
Adding new circuit for recessed lights.... DickieFL Electrical 7 11-21-2009 08:12 PM
Arc Fault Break Tripping when any light switch turned on elab1 Electrical 60 11-20-2009 01:24 PM
Should Ceiling lights be on separate circuit? handyoldgal Electrical 29 03-18-2009 08:54 PM
How many lights on a circuit? How many outlets? helpless handyman Electrical 4 04-14-2008 12:11 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
