Accidental Red To White Wire Issue -Broken Breaker - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 08:01 AM   #16
Originally Posted by nap View Post
who screwed up on this and caused the breaker problem? If the electrician; he needs to be taking care of it out of his pocket.
It wasn't. It was the homeowner.
swataz is offline   Reply With Quote
Old 07-19-2010, 08:03 AM   #17
Originally Posted by frenchelectrican View Post
If this circuit strictly used for luminaires only no recepatles then you are ok with it but if have any receptales feed either kitchen or dinning room it have to be it own circuit with RCD { GFCI } this is very specfic in NEC code plus some local code if that do show up as well.
Merci.
Marc
In a perfect world, and if I had the money to do so, I would have his house AND mine completely rewired.
I am sure that MANY things in my own home are not up to local 2010 code in my area. My home was built in 1959 and the particular house I am talking about was built in 1955.
Old 07-19-2010, 04:54 PM   #18
Journeyman Wireman
Rewards Points: 150
While a Cutler-Hammer BR type twin breaker will fit in a Bryant panel, I'm not certain that they are officially listed for that panel. Cutler-Hammer/Eaton makes Classified breakers (will are listed to fit multiple panel brands) but does not make a Classified twin breaker.
Jupe Blue is offline   Reply With Quote
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
A hot wire buried in the yard that you cannot even trip a breaker by sharting it? BJLower Electrical 3 01-21-2010 02:24 PM
Dimmer wiring in a box with 3 black and 3 white wires and a pink wire to boot! everender Electrical 9 02-15-2009 09:24 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
20 amp breaker on 10/3 wire Duane 70 Electrical 6 09-16-2008 01:02 PM
