Accessing Wire In Ceiling That Has No Access - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2010, 05:59 PM   #1
Rewards Points: 127
Accessing Wire in Ceiling that has no Access
I have a vaulted ceiling in my kitchen and I want to redo the lighting. I want to add a new light fixture, which means running wires. I do not have access in the space above the ceiling. How can you run wires to the new fixtures without destroying the ceiling drywall? Are there any tips or tricks, such as using a wire puller?
Thanks for the help!
wkumtrider is offline   Reply With Quote
Old 01-30-2010, 08:04 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 980
You are going to have to cut holes in the ceiling.
You may be able to get away with small ones, at several locations to get the wire where it is needed.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 01-30-2010, 09:43 PM   #3
Rewards Points: 166
Any chance they didn't staple the existing wire and you could use that as a pull string?
If not there are ways, we use a magnetic puller in tight spaces like that...example: http://mccartenco.net/product.php?productid=1187
hellothere123 is offline   Reply With Quote
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 02:06 PM
Ceiling Fan and Recessed Lighting with No Attic Access...Ugh. caps84 Electrical 1 08-06-2009 10:09 AM
Suspended Ceiling Wire Protection jamiedolan Electrical 1 01-19-2009 08:56 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Running wire to a Ceiling Speaker (in vaulted ceiling) rgmetro Electrical 1 01-09-2008 10:27 AM
