AC Unit Dims Lights - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-30-2009, 11:17 AM   #16
Originally Posted by portclinton View Post
Try updating to a 200 Amp service. I did this on my rental property and the power fluctuations went away. It will also increase the value of your home. Like petey c said above: electricity flow is comparable to plumbing pipes in your home. If you run 3/4 pipes instead of 1/2 inch, the water fluctuation will be a little less. Same with electrical service.
Replacement can cover up what could have been a simple repair, like tightening or cleaning a connection.
Assuming you actually have a problem, I'd put considerable effort into pursuing the root cause. The worst outcome is that you replace a lot of stuff in one expensive chunk, and it doesn't even touch the symptom or actually worsens the symptom.
Old 09-30-2009, 11:26 AM   #17
J. V.'s Avatar
Rewards Points: 348
I have a 200 amp service and my heat pump dims my lights a bit every time it comes on. Just enough to notice. This is normal.
Now, if the utility would have upgraded their conductors when I upgraded my service, it's possible I would not notice when the heat pump comes on. Just upgrading your end does not mean you will correct this.
If it worked before you worked on it. You did something wrong.
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 36 02-25-2018 11:51 PM
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Neighbor's AC dims my lights! knharper Electrical 3 05-23-2009 03:17 PM
Sump pump dims lights Richo Electrical 7 12-20-2008 03:00 PM
central unit will not come on ....please help guyasc HVAC 5 08-24-2008 05:10 PM
