AC Motor Not Starting Properly - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2019, 05:06 PM   #1
Rewards Points: 6
Recently, I have been working to fix an old 115 V AC motor that was exposed to water. When I try to start the motor it hums and vibrates and the stator moves very slowly for a few turns but then is locked in place. Iíll attach a link to the video of the motor starting and a picture with the details of the motor.
What could possibly be the cause of this and what tests could we do to troubleshoot the issue?
I'll post a video link in the replies to this thread.
Thanks for the help
Vsirohi is offline   Reply With Quote
Old 07-25-2019, 05:10 PM   #2
Rewards Points: 6
Re: AC Motor Not Starting Properly
Link: https://drive.google.com/drive/folde...Wo9fFnO1mkn4ls
Old 07-25-2019, 05:15 PM   #3
retired framer
Rewards Points: 8,654
Your links are small pictures only, capacitor???
Do not use flat bottom gables with scissor trusses.
Old 07-25-2019, 06:02 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 30,890
Start winding issue. Possible centrifugal switch issue. Bad contacts? stuck?
Old 07-25-2019, 06:52 PM   #5
dmxtothemax's Avatar
Rewards Points: 7,742
ditto !
starting sequence faulty
cap or switch cannot tell
would need motor brand and model
dmxtothemax is offline   Reply With Quote
Old 07-25-2019, 07:00 PM   #6
retired framer
With out the end and bearing it is just sucking over to the magnet. Put the top on and try it.
Tags
ac motor , electrical , industrial , motor , wiring
