Ac-dc Adapter Needed - Electrical - DIY Chatroom Home Improvement Forum
Old 04-07-2018, 12:38 PM   #1
Rewards Points: 4
ac-dc adapter needed
I need a replacement for a POWER UNIT, details follow:
CHANGZHOU QIBO ELECTRICAL Co., Ltd.
Model: QBD-240050-IP20
INPUT: 120VAC 60Hz 0.25A
OUTPUT: 24VDC 500mA
Class 2 Power Supply
Where do i need to go? Who do i need to contact? (hopefully online? I'm in NW USA)
acdcadapter-1 is offline   Reply With Quote
Old 04-07-2018, 12:46 PM   #2
JUSTA MEMBER
Rewards Points: 3,898
Re: ac-dc adapter needed
Try the manufacturer of your device first, they should have replacement parts.
Then look on e-bay for the Chinese adapter maker in CHINA, may be selling them through e-bay.
ED
de-nagorg is online now   Reply With Quote
Old 04-07-2018, 12:49 PM   #3
Rewards Points: 4
Unhappy
They have gone out of BUSINESS!
Old 04-07-2018, 12:55 PM   #4
JUSTA MEMBER
There used to be universal power supplies made with several different output prongs on the end, you just plugged in whichever one fit your power orifice on the device.
Maybe something like that will work.
Or you might find an entire device including the power adapter on e-bay, in someone's sales listing.
I often get New old stuff there that had been sitting in someone's warehouse unsold.
ED
Old 04-07-2018, 01:05 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 888
There are dozens of the on eBay and Amazon. 500 ma is the minimum you need, more is fine.
https://www.amazon.com/SMAKN-Switchi...c+power+supply
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 04-07-2018, 04:40 PM   #6
Rewards Points: 182
One of these would probably work:
https://www.aliexpress.com/item/Plug...ceBeautifyAB=0
Just one of hundreds of listings. I'd expect to find more of the same on Ebay.
Paulusgnome is offline   Reply With Quote
Old 04-07-2018, 06:05 PM   #7
Rewards Points: 88
I don't know whether the OP has a RCA pin type plug in cord on the low voltage, or wire terminal connection. They have both on amazon. https://www.amazon.com/SLLEA-Replace...t+power+supply
Gregsoldtruck79 is offline   Reply With Quote
Tags
120vac->24vdc , ac-dc , power unit
Installing sill adapter for replacement windows... AllGoNoShow Windows and Doors 3 08-23-2015 06:52 PM
Sweating copper to pex adapter with pex already clamped tk3000 Plumbing 8 04-17-2014 10:13 PM
Prize: A pizza. Problem: Faucet dishwasher adapter size--with picture. erpo41 Plumbing 2 11-27-2013 07:14 AM
Can I safely use a DC9V 500mAh adapter to power 2 CPU fans for DIY reciever cooling? Foxtrot_01 Electrical 11 05-21-2013 02:45 PM
Changing faucet - reverse osmosis adapter grand_canyon Plumbing 4 11-20-2012 10:29 PM
