AC Circuits - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2009, 05:02 PM   #1
R_T
AC circuits
Wondering if anyone can tell me the circuit amperage (breaker, not fuse) for 3 ton, 4 ton and 5 ton AC condensor units.
R_T is offline   Reply With Quote
Old 08-18-2009, 05:09 PM   #2
Different units have different specs. New units require less than older units.
Ballpark, newer units will be appx 10A per ton max breaker size.
The min size will vary.
220/221 is offline   Reply With Quote
Old 08-18-2009, 06:59 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 30,912
Also depends on voltage. If these are commercial and run of 480 or 600 volts, amps will be a lot less. You need the specs for the units you are installing.
Old 08-18-2009, 07:06 PM   #4
And phase
I was assuming resi single phase.
Old 08-19-2009, 08:19 AM   #5
R_T
Thanks guys
Yes it is single phase 240v.
Old 08-19-2009, 11:07 AM   #6
Registered User
Termite's Avatar
The required amperage minimum and maximum of the overcurrent device will be listed on the sticker on the side of the AC unit. That is the only 100% reliable way to know.
Old 08-19-2009, 11:43 AM   #7
J. V.'s Avatar
Rewards Points: 348
I second that.
Old 08-19-2009, 12:10 PM   #8
Licensed Pro
You can also find the minimum ampacity of the conductors there (i.e. wire size)
Old 08-19-2009, 01:26 PM   #9
Registered User
Termite's Avatar
That's one I haven't seen. They always list the overcurrent device ampacity but I've never seen (or noticed) it go as far as to tell you the wire size. Conductor size is determined via NEC table 310.16...Depends on the wire type, material, conduit, etc.
Next time I'm looking at an AC unit I'll have to check that out.
Old 08-19-2009, 03:47 PM   #10
They don't tell you wire size, just min circuit amps.
I hate when it's 21, 31 or 41
AFCI and 3-wire circuits...ugghh mhops Electrical 11 03-17-2010 11:22 AM
Power on several circuits comes and goes all at once, never trips breaker Michael H Electrical 22 06-29-2009 08:22 AM
Entire Rewire or New Branch Circuits? Typ0 Electrical 44 01-29-2009 10:54 AM
replacing old wire on existing circuits... red86yota Electrical 9 12-08-2008 06:00 PM
One neutral for two circuits?? TronCarter Electrical 13 01-14-2007 08:21 AM
