AC Adapter - Electrical - DIY Chatroom Home Improvement Forum
Old 09-08-2009, 07:36 PM   #1
Rewards Points: 20
AC Adapter
Hi there-
I purchased a trash can that has an automatic flip lid http://www.walmart.com/catalog/produ...ct_id=10247571, the unit takes either 4 D batteries or an AC plug (sold separately, of course) http://www.walmart.com/catalog/produ...ndingMethod=rr
I have a shoebox of AC adapters, you know, one of those shoeboxes of stuff that "I'll use someday" that your wife always wants to throw out. Neither the unit, the manual or the website give any voltage/wattage information.
The 3 adapters I have (that fit) include the following info:
1) Class 2 transformer, input 120V, 60 hz, 25 watts, output 12VDC 1000mA
2) AC Adapter, Input 120v-60Hz 22W, Output 13.5VDC 1A
3) Class 2 transformer, Input 120v AC 60Hz, output 12V DC 200mA
I know there's always the "plug 'em in and give 'em a shot" method, but I don't know if I could potentially cause any problems to the motor or create a fire hazard.
Would any of these work?
Thanks, Brent
bsmith6356 is offline   Reply With Quote
Old 09-08-2009, 07:47 PM   #2
I may be wrong, but I think you need a 6volt output unit. 4 batts at 1.5v each equals 6volts.
on edit: You could ask them http://www.itouchless.com/share/cgi-...=home&qd.query
Plumbvoltage is offline   Reply With Quote
Old 09-09-2009, 12:29 PM   #3
J. V.'s Avatar
Rewards Points: 348
Heres how you do this.
Find the trash can on Walmart's web site. If it accepts an adapter it will be listed under "accessories". Or look for the adapter itself. Find the one Walmart sells and make note of the current and voltage. Then make sure the one you find in the shoe box matches the voltage and the current rating is the same or higher as the one you can buy. I have called the manufacturer for this information many times. They will usually tell you what you need to know. Usually.
Or, spend $10.00 and get the right one el cheapo. I know, I'm an El Cheapo myself when it comes to stuff like this.
Note: Be careful. Not all plugs are created or wired equal. Sometimes the pin is hot and sometimes it's not.
If it worked before you worked on it. You did something wrong.
Making a battery powered device work with an AC/DC adapter? FlyGuy Electrical 14 11-21-2010 07:28 PM
Pitless Adapter Submersible Pump Wild Blue Plumbing 5 08-31-2009 01:02 PM
non-grounded to grounded adapter wilkc Electrical 2 06-15-2009 01:18 PM
Adapter for ABS to SCH 40? MikeVila Plumbing 3 11-04-2008 08:48 PM
Removing 2" marble toilet flange adapter for handicapped proofer Plumbing 20 04-21-2008 04:31 PM
