As Above, So Below.... - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 11:21 AM   #1
the Musigician
DangerMouse's Avatar
As above, so below....
I'm putting in the new flooring under the panel today, so I need to know what I need to add to the hole in the 3/4" plywood flooring to run the wiring through?
Do I need a plastic anti-friction ring glued in, does it need to be fire caulked, etc. 3 or 4 wires will come from below. The rest will drop from above. I KNOW I need the fire caulk there.... anything else I should be checking for as well?
Just want to CMA.... Po)
DM
Old 06-29-2010, 12:15 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Holes bored in wood do not need any protection.
Old 06-29-2010, 12:42 PM   #3
Totally screwed together
If you are going to do a hard angle on the wire after the hole, you might want to chamfer the hole so there isn't a sharp edge to abrade the wire.
xxPaulCPxx is offline   Reply With Quote
