60 Amp Sub Panel For A Detached Garage - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 08:47 PM   #31
Inspector/Instructor
codeone's Avatar
Originally Posted by canyonbc View Post
Well thank you for the information.
Are these put out by the manufacture of is that papa NEC Code.?
Just Wondering and Learning
The NEC!
codeone is offline   Reply With Quote
Old 01-11-2010, 12:17 AM   #32
Rewards Points: 150
Good to know
canyonbc is offline   Reply With Quote
Old 01-11-2010, 11:53 AM   #33
Rewards Points: 150
As I continue to learn and dial in the electrical plan for the garage
I wanted to run some things by everyone and get some opinions.
I think it is ok to put a link to The Home Depot of the breakers I am talking about, figure it would be easier to show some links so everyone can really see what I am asking about.
60 amp 2 inch double pole circuit breaker
http://www.homedepot.com/Electrical-...atalogId=10053
100 amp 2 inch double pole circuit breaker
- Ok to recap the situaion, have a main panel with 200 amp breaker going approx. 125 feet to a detached garage, have not determined yet if I want to put a 60 or 100 amp sub panel.
Question:
At the main panel would I put on of these breakers in and then run # 3 awg thwn to the sub panel?????
Has anyone used these is this the way you would do it, if not what would you do and why?
Thanks,
Mike
Detached Garage Sub Panel Grounding Q integlikewhoa Electrical 15 03-12-2015 07:02 PM
How to install sub panel in detached garage 70' away MEC Electrical 5 02-09-2009 05:31 PM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 12:08 PM
New detached garage, wiring, questions gp_wa Electrical 9 12-04-2008 03:10 PM
detached garage Kapt Electrical 12 01-17-2007 08:37 AM
