60 Amp Federal Fuse Panel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2010, 01:04 PM   #1
Hey guys, I have an old 2 unit apartment building that I an rennovating and it has a 60 amp box with the "main and range" disconnects and 4 15 amp fused circuits. My question is what size cartridge fuses should be in the disconnects? Also I am going to be replacing alot of knob and tube with romex in one unit and was planning on running 12-2 for outlets, so could this circuit be a 20 amp with a 20 amp fuse, or will it still be considered a 15 amp even with 12 gague wire?
Thanks!
flatlander745 is offline   Reply With Quote
Old 06-03-2010, 03:04 PM   #2
Rewards Points: 506
you probably have 15 amp outlets.
a chain is only as stong as its weakest link.
forresth is offline   Reply With Quote
Old 06-03-2010, 06:41 PM   #3
Rewards Points: 464
Perfectly ok to used 12 ga for 15 amp outlets, often preferred in new wiring, just not 14 for 20 amp, such as kitchen appliances.
Jim F is offline   Reply With Quote
Old 06-03-2010, 11:10 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Thanks!
If you going to replace a bunch of K&T in one unit I will strongly recomend that you get new load centre to ditch the 2by4 fuse box { 2 cartage fuse plus 4 plug fuse } then you will have to bring all the circuits up to the modern codes and you will need proper permits to do this and if you don't live in that building you must have to get the electrician to come out and deal with it { the electrical code is very specifc on this one }
for the 4,0mm˛ { 12 AWG } conductors you can use either 15 or 20 amp breakers but on 2.5mm˛ { 14AWG } it must be on 15 amp breaker.
There are few spefic codes you have to follow :
Kitchen area you will need minum of 2 SABC { small appalince branch circuit } it have to be 20 amp circuit.{ RCD { GFCI } protecion is required }
Bathroom it will be required to be on 20 amp circuit and it will only goes to the bathroom no other rooms at all { to feed other bathroom it is legit but no light if you go this route }{ again RCD{GFCI} mantory }
any room is not on RCD { GFCI } required AFCI if you are on 2008 NEC code cycle.
There may be additonal requirement especailly with mulitfamily unit or apartment units so check with local office to see what they require.
Merci,Marc
Old 06-04-2010, 07:14 AM   #5
I=E/R
a7ecorsair's Avatar
In Minnesota a non-licensed person can only do wiring in his owner occupied home. You may want to do some checking before you get too far into this as to what your state has for code in this area. Your insurance company may not allow it either.
a7ecorsair is offline   Reply With Quote
Old 06-04-2010, 08:37 AM   #6
Is anyone familiar with Pennsylvania Codes in this area? I know that service needs to be updated, just a cost issue right now.
Old 06-04-2010, 10:38 AM   #7
Electrical Contractor
kbsparky's Avatar
Pennsylvania does not have a state-wide electrical license. Each local jurisdiction has its own requirements, if at all. There are many areas in the state that do not require a permit, or license. What city, town, or township are you referring to?
Best to check with your local building officials, or inspection agency.
-KB
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Electrical Panel "cut-in" question Todd-sta Electrical 52 12-03-2008 11:07 PM
Question about removing a screw type fuse box... OmegaBunny Electrical 9 09-15-2008 10:13 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Blown fuse in Control Panel of Carrier Heater jacksup HVAC 3 02-26-2008 05:02 PM
