6" Halo Recessed Lighting Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2013, 01:14 PM   #1
6" Halo Recessed lighting issue
Installing cans into opening and cannot get them to clip in.
They are insulated and Air- tight..... suggestions?
Homerlion is offline   Reply With Quote
Old 09-21-2013, 01:38 PM   #2
Oso954's Avatar
Rewards Points: 1,232
Insert the can into the hole and hold it up in place.
Push the clip flush against the can wall so that the tip of the clip is in contact with the top of the drywall.
Slide the clip upwards to lock in place.
Repeat for remaining clips.
Oso954 is online now   Reply With Quote
Old 09-21-2013, 03:32 PM   #3
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
what is the thickness of the material that the hole is ???? ..ie 1/2 drywall or ????
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 11-05-2014, 01:12 PM   #4
Rewards Points: 1,102
After using every tool I own and not being able to get the clips in, I did a web search. Looks simple enough. Used a hydraulic jack, a come along, sledge hammer, chainsaw, jewelers screwdriver What the ???
Looks simple enough, press flat against side and push up with screwdriver.
Check the instructions, for 1/2 - 5/8 drywall, right model number, looked at you tube, all to no avail?? I can not possibly be the only one having this issue.
Then 50 plus years of DIY kicked in. Removed from the can the clip is roughly shaped like a v, applying outward force on the V and make the V about 1/4" wider. Reinstall in can push against side and up with screwdriver (flat not philips), SNAP, done!!
HTH someone JIm
jjrbus is offline   Reply With Quote
The Following User Says Thank You to jjrbus For This Useful Post:
petey_c (11-07-2014)
Old 11-05-2014, 02:56 PM   #5
Rewards Points: 58
I've had the same problem. Sometimes they snap right into place, other times ....well. I've used a small hammer at times. Once I used a couple of sheet metal screws to hold a clip in place. I'll have to file your tip away in my walking file cabinet. Thanks for letting us know.
Eddiethekub is offline   Reply With Quote
Old 11-05-2014, 07:40 PM   #6
Thanks for the response. When I tried tapping on the screwdriver with a hammer, all it did was bend the can!
The springs might be bent at different angles, Some people would have no problem. I only used 4 fixtures out of one case.
JIm
Kitchen fluorescent to LED recessed lighting changeout speedytahiti Electrical 1 01-05-2012 07:04 PM
Recessed lighting housing - how to tell if is IC or non IC? daluu Electrical 1 01-02-2012 06:33 AM
Recessed Lighting Job in Shower braves22 Electrical 4 12-19-2011 02:19 PM
older recessed lighting issue kibosh Electrical 3 01-13-2008 03:15 AM
Confused.....Halo H7ICT Recessed Lighting Question tigerbalm2424 General DIY Discussions 5 01-09-2008 07:21 AM
