50 Amp Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 07:58 PM   #1
50 amp breaker
I recently had a the 50 amp breaker trip on my stove, being an old unit I assumed it had a short and was the cause of the tripped breaker, so I had it replaced.Now the breaker will not reset and trips the main coming into the breaker box. Is it possible that the breaker is bad, it is an old one the box is a Murray. Thanks
bigbern is offline   Reply With Quote
Old 12-08-2010, 08:23 PM   #2
Electrical Contractor
kbsparky's Avatar
IF you're tripping the main, you most likely have a problem in the stove or wiring.
The breaker is essentially doing its job in such cases.
-KB
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
GFCI Breaker Tripping Spa Light eaposition Electrical 21 09-08-2010 09:57 PM
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 10:13 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
