4 Wire 220v (240V) Circuit To A 3 Prong (with Ground) Recepticle - Electrical - DIY Chatroom Home Improvement Forum
Old 07-01-2010, 10:45 PM   #1
4 wire 220v (240V) circuit to a 3 prong (with ground) recepticle
i need to add a 220V (240V) outlet in my garage for a air compresser. i have the correct recepticle for the compresser ( a cooper wiring devices 1876w) the breaker is 4 strand....2 hots, 1 neutral, and a ground. the recepticle however has 1 brass (hot) one silver (neutral) and a green (ground) do i put both hot to the brass and the neutral to the silver ////please help?
stonecold5150 is offline   Reply With Quote
Old 07-01-2010, 11:22 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
Is it a 3 prong outlet? Sounds like it may be a 240v and with no need for 120v, in that case you just cap the neutral. You can probably just use 12/2 even, and skip the neutral. I'm assuming this is the receptacle? I believe that's 20a 240v.
The Following User Says Thank You to Red Squirrel For This Useful Post:
stonecold5150 (07-02-2010)
Old 07-01-2010, 11:25 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
most air compressors do not use a neutral.
if red squirrel posted the correct recep, there is no neutral taken to the recep. Yes, you can use 12/2+G.
one of each of the hots to the silver and brass screws. Bare or green to the green ground screw.
The Following User Says Thank You to nap For This Useful Post:
Old 07-02-2010, 12:42 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Nap just a small correction to your part for straght 240 volts receptales there will be no silver screws there.
However if you have 4.0mm˛ twinner aka 12-2 you have to remark the white conductor to red or bleu or use black tape to know that is hot conductor.
{ this part is only legit with cable but for indivual conductors in conduit it is not legit }
Merci.
Marc
Old 07-02-2010, 04:35 PM   #5
nap
You talking to me?
nap's Avatar
Merci.
Marc
either the OP doesn't have the 240 v recep or there is a 240 volt recep with a silver screw.
3 wire with ground to 3 prong dryer plug dgbunk Electrical 9 10-19-2010 01:07 PM
neutral wire became ground? okedomantakeshi Electrical 18 12-29-2009 03:18 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
240V Electric Heater install - 3 wire vs. 4 wire? dhgarage Electrical 7 12-12-2008 10:49 PM
