4 Way Switch?? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 02:37 PM   #1
Rewards Points: 948
4 way switch??
I have a 4 way lighting circuit that doesn't seem to be operating correctly. Basically, when one of the 3-way switches is turned off, the entire circuit is off. Thus, only the 4-way and one of the 3-way switches operates the circuit correctly.
Any suggestions before I go digging into things!!
Master Brian is offline   Reply With Quote
Old 10-07-2010, 06:12 PM   #2
Rewards Points: 1,005
i'd say the 3-way switch that turns the circuit off, is either mis-wired or bad.
TimPa is offline   Reply With Quote
Old 10-07-2010, 06:14 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
is this a new install or an old install gone bad?
If this is something that just happened, I would guess either a bad switch or you lost a connection in one of the travellers.
If a new installation that never worked correctly, something is miswired.
Old 10-07-2010, 09:26 PM   #4
Rewards Points: 948
It was apparently miswired as I opened up and went through the connections and it works now. Thanks!
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
