DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   4 recessed lights and only 1 powers (https://www.diychatroom.com/f18/4-recessed-lights-only-1-powers-46116/)
nyfilm123 06-07-2009 07:54 AM
4 recessed lights in square pattern in kitchen.. 1 of 4 lights gets power.. The other 3 don't power..
I have a Y connection running off the main to the 2 front kitchen lights and then those 2 spots i tapped off of to connect the other rear 2..
Each light has a 4 port insert connector on (halo 6inch remodel housing)... Have those been known to cause trouble or is there a particular order they must be connected in for those ports??
I know my connection from the main Y'd of the main is solid.. I used all 12 guage wireing..
nyfilm123 06-07-2009 09:15 AM
Any suggestions?
J. V. 06-07-2009 10:02 AM
Did you physically check for voltage at each fixture? This must be done first. Are these florescent fixtures? Are they new? Did they work before? If power is present in the connection box, it has to be the fixture. However, I do not understand all of your statements, so I really do not know what you are talking about. "Y" connection. What do you mean by this and what country are you in.
hayewe farm 06-07-2009 10:31 AM
It sounds like your problem is at the "Y" connection, if that connection was good and proper you would at least have 2 lights with power.
nyfilm123 06-07-2009 10:42 AM
I found the issue.. The Halo trim has a housing on it that mounts to the light socket... The halo trim brase was made a little too narrow... causing the bulbs to be slightly ajar... Who would have thought.. i cursed myself.. I couldnt believe it.. Of all things.. The housing around the socket due to that it was tight made it believe it was all the way in ...
Lesson learned.. At least my connections and wireing was secure..
Thanks...
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
