4 Gang Box, Grounds? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2012, 06:34 PM   #1
Rewards Points: 77
4 gang switch box. power into this box. All wire is 12 Guage.
Neutrals and hots are easy to nut together, 5 at most in 1 nut.
But what about the ground wires? There will be 9 total ends that need to be connected, 9 seems like alot under 1 wire nut.....or is it? lol
Can i make up 2 sets of grounds and use a jumper between the 2 wire nuts?
Do they make a wire nut for 6 wires?
bryan1282 is offline   Reply With Quote
Old 05-04-2012, 08:12 PM   #2
Missouri Bound's Avatar
Rewards Points: 3,552
Of course....
Do you want it your way or the right way?
Missouri Bound is online now   Reply With Quote
Old 05-04-2012, 08:15 PM   #3
Licensed electrician
Rewards Points: 3,840
They make up to 8 port push-in connectors too.
bryan1282 (05-06-2012)
Old 05-04-2012, 08:35 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Or a large ground crimp, leaving four tails long for the devices.
Oh the joys of using #12 for lighting. Have fun with that.
Just sit on the floor, in the middles of the room, legs crossed, and chant: Bigger is better. Bigger is better. Bigger is better.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 05-04-2012, 08:38 PM   #5
You could also use one long tail to catch all four devices.
Old 05-04-2012, 08:43 PM   #6
It's funny, when I was a maintenance electrician 12 ga. wire was common everywhere at the switches....but it was all stranded. 12 ga. solid is a real to work with.
Old 05-04-2012, 08:53 PM   #7
Sparky
Rewards Points: 510
Ill take 12 solid over 10 every day.
Techy is offline   Reply With Quote
Old 05-04-2012, 09:46 PM   #8
Pure Genius
Rewards Points: 150
Atleast he aint using 10 gauge
Dierte is offline   Reply With Quote
Old 05-04-2012, 11:44 PM   #9
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,014
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
In a case like this I leave one ground long enough to catch all devices then wire nut the end of it to the rest of the ground wires.
This helps a lot especially when dealing with six gang switch boxes.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
Old 05-04-2012, 11:47 PM   #10
rrolleston's Avatar
Had someone want me to do some branch circuit wireing with 10 gauge once because he got a deal on it from a buddy said no way.
Old 05-06-2012, 12:24 PM   #11
Rewards Points: 77
Nice ideas. i like the push in connector idea. I have been kinda nervous about those but i have seen them recommended a bit here. maybe for this box i will use them for the grounds, maybe ill use them for all the connections in this one box, see how they work out.
I ran 12 for a outlet re-wire of a large family room and didnt have any issues with it. So i used the leftover 12 guage for the lights and installed 10 75-watt recessed lights and wanted some space to add a few ceiling fans with lights in a back room next to the family room that i may or may not redo. Lights and outlets are seperate circuits.
12 guage isnt hard to work with, you guys need to just stop crying so much.
Thanks for the help!
Old 05-07-2012, 09:46 AM   #12
rrolleston's Avatar
Be carefull with the ceiling fans I learned once after I had to go back and put the four ceiling fans with lights on a separate circuit. They were fine alone but once the homeowner stated plugging other stuff in they would trip the breaker after a few min of use. I wish CFL bulbs were available then.
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
Cutting/capping old cables - What to do with grounds & put these in oversize gang box darlingm Electrical 3 12-22-2011 11:40 AM
Dual Bath Vanity GFCI - Single Gang Boxes or a Single Two Gang Box? WoodmanFL Electrical 2 12-11-2011 07:39 PM
rough inspection grounds bfan781 Electrical 8 04-12-2010 04:36 PM
2 gang old box, made into 3 gang, off center?? fabian Electrical 9 01-15-2010 09:46 AM
