3way Switch, With 3 Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2010, 01:24 PM   #1
3way switch, with 3 lights
Im wiring up a 3 way swithc using a how to basic wiring book. It shows how to wire with two fixtures but not with 3. What i have is power through the fixtures with the switches at the end of the run. Im having trouble making the connections at the middle fixture. Im running 12-3 wire between then and 12-2 between the last light and the first switch.
Im thinking black incoming to black outgoing, ground to ground. Pretty sure on that. Then the red incoming to the black on the fixture and the outgoing red? Incoming white to the fixture white and the outgoing white?
eagertolearn is offline   Reply With Quote
Old 02-26-2010, 04:12 PM   #2
Electrician
Rewards Points: 910
So does it go power to light 1, light-2, light-3, switch 1, switch 2
darren is offline   Reply With Quote
Old 02-26-2010, 04:32 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 980
Inside the first light, connect the hot black to the red of the 3 wire, connect the whites together, and connect the black of the 3 wire to the black of the light.
At light #2 connect he reds together, connect the whites together and the blacks together. Continue until you get to the last light.
At the last light connect the red wire to the white wire going to the switch, connect the black wire from the switch, to the black wire of the light and the black wire of the 3 wire.
Connect the white wire from the 3 wire to the white wire of the light.
At the switch, connect the white wire, after tapping it black, to the bottom of the switch, and connet the black wire to the top of the switch.
Hope this worked out, cause I hate to proofread it!
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 02-26-2010, 05:15 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 24,038
Here's the drawing
Old 02-26-2010, 05:53 PM   #5
Originally Posted by joed View Post
Here's the drawing
Attachment 18139
thanks, got the replys just in time to have the wiring done on our new can lights right before my wife got home from work. She expressed her gratitude.
2 lights 1 switch lymantuttle Electrical 10 01-04-2010 05:49 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Wiring Outlets Then Switch Then Lights heydj Electrical 9 05-07-2009 08:09 PM
Wire Multiple Lights controlled by 4-way Switch? mfleming Electrical 17 11-20-2008 08:46 AM
3way switch satsu Electrical 18 09-08-2007 09:28 AM
