3way With With Pilot Light? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-29-2019, 01:59 PM   #1
Rewards Points: 1,052
3way with with pilot light?
I have switches for my garage in the garage and in the entryway. I am always forgetting to turn the light out when I come in. You can't see it from the house, so it can stay on for a day or so.
If I could get a switch with a pilot light that would solve my problem. Unfortunately the power comes in at the entryway and that won't work on the only switch I can find; it powers the pilot light with a jumper off the wire that goes to the light. That would be fine for the switch in the garage, but I don't need it there. It would require an extra wire run from one switch to the other, and it is all drywalled; so that's not going to happen.
Any suggestions? I mean other than being more careful. Thanks
Toller is offline   Reply With Quote
Old 01-29-2019, 02:29 PM   #2
Rewards Points: 698
Re: 3way with with pilot light?
install a timer switch that automatically turns the lights off after X number of mins
anyacolo is offline   Reply With Quote
Old 01-29-2019, 02:43 PM   #3
Rewards Points: 1,276
ditto on the timer switch or
put a motion sensor in the garage and it will turn on and off automatically when you are there.
3way with with pilot light?-white-lithonia-lighting-motion-sensors-cmr-9-64_1000.jpg
curiousB is online now   Reply With Quote
Old 01-29-2019, 03:29 PM   #4
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,406
Make your own pilot light.
Add another fixture somewhere that you CAN see from the house
TarheelTerp is online now   Reply With Quote
Old 01-29-2019, 03:47 PM   #5
Since it is all drywalled, adding ceiling motion sensors or convenient pilot lights isn't going to work. I've added wires to insulated walls before, and even when it is easy, it isn't.
The timer idea is good, but all the ones on Amazon was programmable and inappropriate. I found one that just has you push a button for 5 or 10 minutes or whatever, but the reviews say it isn't 3way. Since it only has 3 wires coming out of it; I think they are correct.
BUT... there are 3way motion sensors that turn off after a preset time when there is no occupancy. It will be blocked by a car, so I don't think it will work as a motion sensor, but if i can turn the inside switch on, and the motion sensor will turn it off 30 minutes later, that will work. I have posted a question to see if that is true.
Appreciate everyone's help.
Old 01-29-2019, 04:05 PM   #6
Rewards Points: 550
Here you go, a simple 3-way switch with a pilot light.
http://waterheatertimer.org/How-to-w...ht-switch.html
Andrew
Handy Andy In Mt Airy NC
HandyAndyInNC is online now   Reply With Quote
Old 01-29-2019, 04:43 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 50
Install LED lamps and don't worry about leaving them on.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 01-29-2019, 05:04 PM   #8
Oso954's Avatar
Rewards Points: 70
It won’t work without a neutral.
A 3way between a detached garage and the house must originate from the garage. Installed with xx/3 wiring, you have 2 travelers and one common (or switched power) going back to the garage. There is no neutral in that cable or conduit. (It would have to be a real recent xx/4 (or xx/2/2) cable to have a neutral)
No, you are not allowed to grab a house circuit neutral even if it is in the same multi-gang box.
Oso954 is online now   Reply With Quote
Old 01-29-2019, 05:04 PM   #9
Super Moderator
joed's Avatar
Rewards Points: 29,228
Andrew
Won't work unless you install it at the switch with the load and a neutral. Op has stated that is the switch in the garage, not the one in the house.
Old 01-29-2019, 05:22 PM   #10
Andrew
If you look at the wiring diagram about 1/3rd down the page, there is a hot, two travelers, and a 4th wire that come from the bulb that powers the pilot. I have no way to run that wire.
The diagram shows it coming from the bulb's neutral while Leviton has it coming from the bulbs hot; but since I can't get at either...
The switch in the garage can get at the bulb's hot, but I can see the bulb from there and don't need a pilot.
I think the LED bulb might be the best idea. If I leave it on a few extra days, its no biggy.
Old 01-29-2019, 05:55 PM   #11
Rewards Points: 374
Install an illuminated 3-way in the entryway. When it's illuminated, the garage light is out. When it's not illuminated, the garage light is on.
LawnGuyLandSparky is offline   Reply With Quote
Old 01-30-2019, 02:48 PM   #12
The illuminated switch is the opposite of what I want, but thought it might work. But they say it is only for incandescent bulbs. Apparently LEDs don't draw enough current to make the switch go dim. Oh well.
But, I might have an answer.
https://www.amazon.com/gp/product/B0...WCSQNKZTF29XMM
Guy with one says that he tried turning it on with the regular switch and the motion sensor switch turned it off after the preset time.
I think that is as close as I am going to get.
Again, I appreciate everyone's help.
Old 01-30-2019, 03:04 PM   #13
Contractor/Engineer
Rewards Points: 1,136
Insteon switches.
They have indicator lights and communicate through your existing wiring.
I've used them for years and you can add switches to any room without the need to run a new wire from that location to the fixture.
A little pricey - but you'll love them!
Domo is offline   Reply With Quote
Old 01-30-2019, 03:09 PM   #14
Rewards Points: 550
There is just no pleasing this person. Then figure out something for yourself that will work for you. If you really wanted a switch with a pilot light, you would find a way to get another wire out there.
How about just work on your memory with some ginkgo biloba.
Andrew
Adding a light to the end of a 4way switch circuit TheFutureYou Electrical 17 10-23-2018 08:33 AM
Pilot light nozzle/orifice emits gas, but doesn't stay lit. hellohello HVAC 2 10-12-2018 02:16 AM
Carrier 58GSC Furness- Got Pilot but Burners Won't Light Up and Run sellstuff HVAC 13 12-04-2017 12:30 AM
Pilot light wont stay lit...Circuit problems? Lavid2002 Appliances 3 12-09-2012 04:21 PM
Question on the ever popular pilot light Bushman HVAC 5 10-14-2012 02:35 PM
