347 To 120 Volt - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2010, 02:14 PM   #1
347 to 120 volt
I have a 347volt lighting ballast that I want to use in my workshop, but I'm unsure of what I have to do to get it to work on 120. Can anybody point me in the right direction?
tweegle is offline   Reply With Quote
Old 03-31-2010, 02:39 PM   #2
Just buy a 120V ballast, that's probably the cheapest and safest option.
DetroitEE is offline   Reply With Quote
Old 03-31-2010, 04:27 PM   #3
Electrician
Rewards Points: 910
Unless it has multitaps(347, 277, 120V, etc) then that ballast is no good to you. Go buy the right ballast.
darren is offline   Reply With Quote
Old 03-31-2010, 07:50 PM   #4
Idiot Emeritus
Rewards Points: 80
You could use a transformer to step the 120 up to 347, but the transformer would be more expensive than a 120 volt ballast.
Rob
micromind is offline   Reply With Quote
Old 03-31-2010, 08:46 PM   #5
Master Electrician
Rob
I would pay for pictures of that .
you know you can buy a 120v flourescent light at home dept for $20? the ballast is almost worth more than the fixture.
andrew79 is offline   Reply With Quote
Old 03-31-2010, 09:14 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Yeah for resdentail grade luminaires but for commercal / industrail location it kinda toss up depending on how bad and the condtion of the luminaire.
I just have one ballast changed in the spray booth that luminaire is Expolision proof but kinda tough to get into the ballast but got done changing it.
{ for readers the Explosion proof luminare will cost about 800 to 1500 }
Merci,Marc
Old 03-31-2010, 09:26 PM   #7
Master Electrician
Merci,Marc
the light in question is for his workshop so i'm assuming it's just straight forward....but i hear where your comming from...we did some lights for holding cells at an airport and being tamperproof they weren't real easy to work on. i'm still trying to find those code references for you as well.
Old 03-31-2010, 09:29 PM   #8
Yeah I can see where this going and the last tamperpoof luminaire I have to use the special spanner wrench to get the bloody thing apart before I get the gaz axe { cutting torch }
For the code references naw no rush on that.
Merci,Marc
220 volt circuit GFCI Captflx Electrical 16 09-29-2011 06:53 AM
VA (volt amps) Captflx Electrical 8 01-29-2010 02:15 PM
20 amp 240 volt konabear Electrical 9 11-18-2009 03:10 PM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 10:49 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
