30 Amp Outdoor Receptacle Location - Electrical - DIY Chatroom Home Improvement Forum
Old 01-29-2010, 08:49 PM   #1
30 amp outdoor receptacle location
I am ready to install a 30 amp outdoor receptacle. Is it ok to mount it right next to the main meter? or does it have to be a certain distance away from that or any other utility such as gas and phone. thanks
daddyrabbit is offline   Reply With Quote
Old 01-29-2010, 08:59 PM   #2
30a for RV plug-in... or... ?
I'd locate it maybe a little distance away in case any meter work needs to be done
Old 01-29-2010, 11:01 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it is legal to place it right near the meter but, as SD said, you might want to give a little bit just in case.
don't forget your weatherproof cover (most likely)
Old 01-30-2010, 07:59 AM   #4
thanks. It's for my generator . I have the meter then about 1 foot away is the cable box. I was going to mount it in between the two. This way it's basically in between the same studs as the sub panel.
Old 01-30-2010, 08:37 AM   #5
nap
You talking to me?
nap's Avatar
you are putting in a transfer switch, right?
Old 01-30-2010, 09:10 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 946
Sounds like maybe a suicide cord!
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 01-30-2010, 09:26 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
You mean inlet box? RIGHT????
PLEASE don't tell us you are installing a regular receptacle with a suicide cord!
Old 01-30-2010, 09:26 AM   #8
Yeah, you don't want an outlet, you want an inlet
Old 01-30-2010, 09:57 AM   #9
And a transfer switch or main breaker interlock.
Old 01-30-2010, 11:18 AM   #10
nap
You talking to me?
nap's Avatar
man, you guys are no fun.
it is especially funny as I currently have a circuit in my house back fed via a suicide cord plugged into a recep on the good circuit and a recep on the bad circuit.
yes, it is only temporary. the weather is preventing me from fixing it right at the moment but I have to have lights and a vent fan in the poo room.
Old 01-30-2010, 12:17 PM   #11
yea--same as pictured (inlet) it's going to my sub panel which has an interlock between the 100 amp in breaker and 30 amp in generator. So it's a 100 amp sub panel or you can call it a 100 amp transfer switch.
Old 01-30-2010, 02:35 PM   #12
Hey, I remember that now from your other thread.
Way to go.
Old 01-30-2010, 02:55 PM   #13
Nice, that's what I need on my 100a sub
But I recd a Genpac kit with 6 breakers when I bought the Gen from a friend
And I have a main breaker sub too (free)
Old 01-30-2010, 08:26 PM   #14
free is always good
move 2 switches new location, replace with 2 for new lights qchawkfan Electrical 3 01-24-2010 11:15 AM
Well Pressure Switch Location dshcs Plumbing 4 02-05-2009 09:04 AM
Number, Size, and Location of Celing Vents GeauxCajuns82 HVAC 7 11-13-2008 10:40 AM
L/R Drain bath/shower over center drain location in floor? tigerbalm2424 Plumbing 2 12-04-2007 01:26 PM
