30 Amp 240 Volt Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2009, 08:53 PM   #1
Unhappy
30 amp 240 volt circuit
I bought a construction heater that is 30 amp 240 volt. I bought a special receptacle for it and a 30 amp double pole breaker. I used #10-2 wire. I connected the black to one side of the breaker and the white to the other side. This didn't leave me a neutral wire. Now when I turn the breaker on it trips off right away. What have I done wrong??
Thanks,
Blaine
blaste is offline   Reply With Quote
Old 07-19-2009, 08:58 PM   #2
240V doesn't have a neutral. Two hots only plus the ground.
The problem is likely at the heater end.
220/221 is offline   Reply With Quote
Old 07-19-2009, 09:00 PM   #3
Do you mean I connected the plug wrong? The breaker trips without the heater being plugged in.
Old 07-19-2009, 09:00 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Agree. it sounds like you wired the breaker side correctly.
What did you do with the white wire at the heater receptacle? The receptacle should not have had a place for a neutral.
Old 07-19-2009, 09:07 PM   #5
I just connected the black to one side and the white to the other, and ground to ground.
Old 07-19-2009, 09:09 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,444
Somewhere, somehow you shorted the wires.
Maybe when you stripped them.
Disconnect the wires at the breaker and see if the breaker holds.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 07-19-2009, 09:33 PM   #7
Is it a 240V "plug"
Maybe the heater doesn't work??
220 volt circuit GFCI Captflx Electrical 16 09-29-2011 06:53 AM
120 volt off 240 volt circuit Captflx Electrical 6 03-09-2009 07:53 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
