3-Way Switches This Easy? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-20-2010, 10:31 PM   #1
Rewards Points: 358
3-Way Switches this easy?
We have really wanted a three way switch in our living room, whom ever designed our layout was a moron haha!
I was in my attic and I examined the wires, this is how it appears (it may be different but this appears to be correct)
after drawing that up, I wanted to try to figure out how to get a 3 way switch in there.. I came up with this, but I have no idea if it will work.
cbzdel is offline   Reply With Quote
Old 06-21-2010, 12:16 AM   #2
Union Electrician
goose134's Avatar
As long as that one splice is in a box, it'll work.
goose134 is offline   Reply With Quote
Old 06-21-2010, 01:09 AM   #3
" Euro " electrician
frenchelectrican's Avatar
To add three way switch it is not super hard to do it just unhook the single pole switch and set it aside and fish in new XX-3 NM cable thru the wall cavity and run that to the new switch location however you will have to remark the white conductor { it is allowed on cable only the indivual conductors no it can't }
It pretty easy to do it and you will have to find one hot conductor that you take that from oringal switch box and wirenutted the remarked white conductor as hot feed that will go to the new switch box location and use that as common { you will find it marked either common or dark colour screws } the other two are used for shuttle { traveller }.
Oh yeah you may end up get a old work box { you may need two for sure }
Merci,Marc
Old 06-21-2010, 07:35 AM   #4
Rewards Points: 2,800
Tiny detail.
With the power connected to the near switch and the light connected to the far switch as you have it, do not use the white wire to connect to the light.
If power is connected to the far switch and the light connected to the near switch, it is okay (actually recommended) to connect the power to the white wire and use the red and black for travelers.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 06-21-2010, 10:20 AM   #5
Rewards Points: 358
AllanJ is this what you are saying?
I am more of a visual kinda person when it comes to the electrical stuff..
Old 06-21-2010, 12:47 PM   #6
Yes.
Running the light feed to the near switch or the far switch is a free choice.
It's just that the switched power to the light fixture may not come back on the white wire even if marked with tape.
Old 06-21-2010, 01:45 PM   #7
Super Moderator
joed's Avatar
Rewards Points: 23,958
The first drawing was fine. However you need to change one of those black wires to a white if you are using a cable. The middle one that connects both switch should be a white one.
The second drawing works exactly the same as the first one.
Old 06-21-2010, 02:22 PM   #8
Rewards Points: 358
gotcha, correct one would be a white wire and I am using a standard 14/3 romex.
Thanks guys! This is ALOT simpler that I though it would be
I was thinking I would need to re-wire the while lighting circuit.
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-20-2010 11:12 PM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 10:09 AM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 06:19 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
Easy upgrade....almost burned home down? Jemo Electrical 3 03-05-2007 10:58 PM
