Thread Tools | Display Modes |
#1 |
![]() 3 way switch question
I have two 3-way switches for a hallway light. It looks like power comes into each switch from a different cable for each. Does this sound right. If I connect the cable for the line coming in from the breaker to the wire going to the top switch I get power only to that switch and not to the bottom. The switch on the bottom has a red black and white that goes down to the same box that the first is connected to but at this point I did not connect it back since the wire going to the top switch only has a back and white. Any help appreciated. I am confused here.
Sponsored Links | |||
Advertisement |
#2 |
there won't be two incoming sources of power for the circuit. based on your description, sounds like two-wire power into one switch, three-wire cable between the switches and then two -wire out to the light at the second switch.
The Following User Says Thank You to itsnotrequired For This Useful Post: |
Frankbruno (11-23-2013)
Advertisement |
#3 |
Ok this is a very primitive drawing but this is what I am up against. This is what it looks like at the box in the basement.
Advertisement |
#4 |
is that the box with the light in it?
#5 |
No it is just the box with the wires in it The light and switches are upstairs in a hallway. One switch is at the top of the stairs with the light and the other switch is at the bottom of the stairs.
#6 |
If I connect the. 3 blacks together and 3 whites together I get power at both switches but the light does not go on. I do not know where the red would get connected to complete this I guess
#7 |
E2 Electrician
Rewards Points: 2,970
How was it wired before? And why did you touch it?
The Following User Says Thank You to stickboy1375 For This Useful Post: |
#8 |
you'll need to expand your sketch. show the box, the switches and the light and the wires between them. the sketch you posted seems to indicate two-wire to the switch, which makes no sense. there needs to be three-wire at each switch for a three-way to work.
#9 |
E2 Electrician
Just a guess, but I would feed the black going to the 3 wire cable, Red and white would be travelers, the remaining whites get tied together, and the remaining black would go to the odd colored screw on the 3-way switch….
#10 |
Before there were 3 breaks in the box. One went to a outlet that a microwave was used and an out let for the gas stove. The 2nd went to a bathroom and the 3rd was this one one day while using the microwave the power went out and it was not just a tripped breaker. Turned out the liner from the breaker to this box had to be replaced. So when I replaced it I ran one new line for the microwave and gas stove. A new one for the bath room and now I want to either tie this one back into the bathroom or it's own line. And yes I made the big mistake of not labeling how it was before. Now I don't know how to get it back
I'll run down and take a few pics to show what I am looking at. |
#11 | |
E2 Electrician
![]() Quote:
#12 |
Here is the picture
#13 | |
Master Electrician
Rewards Points: 5,140
![]() Quote:
The Following 2 Users Say Thank You to brric For This Useful Post: |
stickboy1375 (11-23-2013),
tfo411 (11-23-2013)
#14 |
Super Moderator
![]() Join Date: Mar 2005
Rewards Points: 29,540
You can't make it work with those wires.
Where is light connected into this set up? |
The Following User Says Thank You to joed For This Useful Post: |
#15 | |
![]() Quote:
Ok I wrote down all the wires that we're going into one box. ( see attached pic). I am trying to find how these all go back together again. (They were all connected somehow in this box before) I know I did the mother of all mistakes by not labeling them. The outlet that says stove is for a gas stove not an electric stove. Last edited by Frankbruno; 11-23-2013 at 02:23 PM. |
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
3-way switch wiring question | brightlight | Electrical | 8 | 12-30-2014 06:50 PM |
fan/light switch buzzing | mjlocat | Electrical | 4 | 05-23-2010 03:44 PM |
3-way light with a twist | Jeepsail | Electrical | 14 | 05-18-2010 02:24 AM |
3 way switch question | brons2 | Electrical | 11 | 03-08-2010 02:58 PM |
Another 3-way switch question. | perpetual98 | Electrical | 10 | 07-21-2009 12:16 PM |
