3-way Switch Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2009, 01:48 PM   #1
3-way switch problem
Hi, I have a similar 3-way switch problem as the one reported recently by Blade_316. There are 2 3-way switches, but there is only 1 combination of the 2 switches where the light is on. In one switch 1 Ive got:
Red - common
White - travelers
Black - travelers
In the switch 2 Ive got:
White - common
Red travelers
White travelers
2 Blacks tied together
I'm thinking that if I reverse the red and white wires in switch-1, that it might work (ie. connect white to common, and make the red a traveler). Can anyone confirm that? Also, if I screw this up, can I short something out (or worse!!)?? Thanks very much.
quigleybmd is offline   Reply With Quote
Old 12-30-2009, 01:57 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,968
Looks like maybe you have switch loop like this drawing. two black together makes me think the black at the first swtich should be the common.
Old 12-30-2009, 06:54 PM   #3
Thanks Joed. I think your diagram is supposed to be what you think
I currently have, correct? (and not the 'correction'). I'm not sure,
because in switch 2 in your diagram (switch 1 in my original message),
I have a red wire currently connected to the common terminal of that switch (and you show a black connected to the common).
I'm going to probe some voltages tomorrow, and will append a new message with those. Thanks again.
Old 12-30-2009, 08:32 PM   #4
Super Moderator
joed's Avatar
The colours may not be the same. You have to note which wire is connected to the common of the switch and make sure it is connected to the proper matching wire at the other end. You could have the red and the black swapped between the switches in your setup.
The key to the setup is that the two wires from the fixture need to be connected to the common terminals.
Old 01-01-2010, 06:03 PM   #5
Joed,
I made the black 'common' in the first switch, and that corrected
the problem!! The two switches now work properly as 3-way switches.
Thanks very much! Happy New Year.
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Switched receptacle wiring problem. sheshore Electrical 6 09-27-2009 01:37 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
3 way switch problem Rschrei518 Electrical 2 01-04-2008 12:35 AM
combo switch problem electric1 Electrical 2 06-11-2004 10:11 AM
