3-way Switch Circuit W/light On Each End. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 06:34 PM   #1
Question
3-way switch circuit w/light on each end.
I would like to add a light to a 3-way hall light circuit. The power enters at the first light. I would like to add a light after the second switch. I know I could run a wire back to the first light. Is there a way to simply add it to the 2nd switch? I've attached a drawing of my current circuit.
Thanks for your help.
Ray
rcraighead is offline   Reply With Quote
Old 05-31-2010, 06:45 PM   #2
Licensed electrician
Rewards Points: 3,652
You do not have a neutral wire at either switch. The easiest way would be to run a new cable from the first light to the new light.
Old 05-31-2010, 06:46 PM   #3
Mad Scientist
Your neutral only goes as far as the first light box, so you would have to run a new cable from there. These are my favorite diagrams of the different possibilities: http://www.easy-do-it-yourself-home-...g-diagram.html
McSteve is offline   Reply With Quote
Old 05-31-2010, 06:58 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 23,938
If you convert the switches to a wireless system like an X10 I think you could make it work. Otherwise you need new cables to do it hardwired.
Old 05-31-2010, 08:00 PM   #5
If you go with a wireless system make sure the frequencies and modulation scheme won't interfere with your brand of AFCIs.
The three way systems boil down to a 'composite' single pole single throw switch in series with a load [the lamps] and the source [120vac]. So, somehow the two lamps have to be in series and the actual wiring method/diagram and colors should be NEC compliant.
Old 05-31-2010, 09:44 PM   #6
Thumbs up
Thank you all, for your responses and thanks for the link to the excellent 3-way switch diagrams.
Old 06-01-2010, 10:57 AM   #7
What program did you use to make that diagram?
Makes a nice diagram.
tdeg807 is offline   Reply With Quote
Checking circuit load for recessed lighting Nathan0115 Electrical 12 05-07-2010 03:49 PM
Branching off existing circuit schnitz411 Electrical 13 03-14-2010 10:11 PM
Adding a switch and new lights to a circuit? mj876 Electrical 5 03-07-2010 04:10 PM
Adding a 2 way switch to a 3 way circuit bkasl Electrical 8 01-03-2009 01:45 PM
add a second light to an existing 3 way switch circuit djohns10 Electrical 6 03-02-2007 07:16 PM
