3-way Switch 2 Fixtures - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2016, 01:54 PM   #1
Rewards Points: 6
3-way switch 2 fixtures
Hello. I would like to wire a 3-way switch to 2 fixtures but not in the usual way. I want to wire so that in one position one fixture is on and in the other position the other fixture is on. Doing this so that when the "main" lamp isn't on there's a low wattage LED bulb on. Doing this in a dark hallway. I actually know how to do this. Is it legal according to the NEC? Thanks.
regisp is offline   Reply With Quote
Old 10-17-2016, 02:03 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,970
Re: 3-way switch 2 fixtures
Tell us what you are planning to do. Then we can determine if it is legal. I can not think of any reason that it would be banned.
Old 10-18-2016, 08:07 AM   #3
Rewards Points: 6
Thanks for a quick reply. I actually worked as an electrician over 30 years ago. I know a lot has changed.
I plan on installing an additional fixture in a hallway. I want one of the 2 fixtures to be on at all times. With the 3-way switch in one position one of the fixtures is on, with the 3-way switch in the other position the other fixture is on. I want to do this so that a low wattage LED is always on as a guide or night light in a dark hallway when the main higher wattage light isn't on.
Again, thanks.
Old 10-18-2016, 09:59 AM   #4
Rewards Points: 2,524
What you really require is to wire up one Single Pole Double Throw (SPDT) switch to operate either one of two lamps - so that one or other of them is always on.
I cannot see any problem with this.
As a point of interest, I have a situation where the Common of an SPDT switch goes to an external (porch) lamp and in the "operated" position connects the lamp to the Line.
However, in the other (off) position the lamp is connected to a "switched" Line derived from an out-doors movement sensor.
So, I can switch the lamp concerned on and off individually but it also comes on along with the other external lamps operated by the sensor.
FrodoOne is offline   Reply With Quote
Old 10-18-2016, 10:31 AM   #5
Rewards Points: 6
That's what I was thinking since a 3-way switch is just an SPDT. I like the idea of your wiring. However in my instance I would connect to a remote dusk to dawn sensor rather than a motion detector.
Thanks for the input.
Troubleshoot a 4-way switch circuit: instructions for a 2-year-old pete0403 Electrical 22 09-28-2019 09:54 PM
Installing Honeywell 3-way timer switch PLS750C Jaluddeke Electrical 11 10-10-2014 03:20 PM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
