3-way Bathroom Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2014, 09:50 AM   #1
Rewards Points: 34
3-way bathroom switch
How do I wire a 3-way switch in my bathroom so that it doesn't require both switches to be "on" to turn on the lights? Here's how it's wired now.
Power to #1 switch via 12-2
14-3 from #1 switch to #2 switch
Blacks connected to switches
Whites connected to each other
Power out from #2 switch to lights.
Sent from my iPhone using diychatroom.com
Queef is offline   Reply With Quote
Old 08-05-2014, 10:03 AM   #2
Licensed electrician
Rewards Points: 3,740
I hope this is a 15 amp circuit as the #14 is too small for a 20 amp circuit.
Power in and power out on the common screws of the switches. Black and red of the 3 wire cable are the traveler on the brass screws of the switches. Whites splice through. All grounds together and to the switches.
Old 08-05-2014, 01:53 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 30,950
You didn't say what you did with the reds.
Old 08-05-2014, 02:40 PM   #4
Rewards Points: 34
Lol.... My bad. I hooked both blacks up on the same side with the reds hooked on the opposite.
Old 08-05-2014, 02:53 PM   #5
The connections on the traveler screws does not matter as long as the correct wires are used. Also left, right, top and bottom all depends on brand and orientation.
Old 08-05-2014, 03:01 PM   #6
Rewards Points: 34
I suppose I don't know how to upload a pic from my photos on my phone. It says I don't have permission.
Old 08-05-2014, 03:13 PM   #7
Rewards Points: 34
http://images.search.yahoo.com/image...ne&fr2=piv-web
Old 08-05-2014, 03:15 PM   #8
Rewards Points: 34
Old 08-05-2014, 04:06 PM   #9
Those diagrams show the same thing I described and as Joed already posted.
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 04:22 PM
Wiring help for a timer switch (for bathroom exhaust fan)! vanny Electrical 12 07-10-2012 08:58 PM
Problem replacing bathroom lightswitch rockchalk Electrical 7 12-19-2011 06:57 AM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 10:57 PM
replacing light switch in bathroom cooper Electrical 3 02-22-2007 05:05 AM
