3 Sets Of Wires Going To 1 Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2010, 07:08 PM   #1
3 sets of wires going to 1 outlet
is it safe to put anothert set of wires into an outlet that already has 2 set of wires going to them (black,white and ground) there connected via the pushins in the back of the outlet leaving the 2 brass and 2 neutral free.
cejkwo is offline   Reply With Quote
Old 06-30-2010, 07:50 PM   #2
Licensed electrician
Rewards Points: 3,644
The backstabs are only for one wire each. you can join the wires together with a short length of the correct gauge and then connect to the screws.
You may not have enough cubic inch capacity to add more cables.
cejkwo (07-01-2010)
Old 06-30-2010, 08:24 PM   #3
think you misunderstood. there is only 1 wire in each, the brass and neutral SCREWS are not in use, can I use them giving the outlet 3 sets of wires, I want to go from this outlet to power another outlet that I want to add
Old 06-30-2010, 09:01 PM   #4
I=E/R
a7ecorsair's Avatar
Well, you can do what ever you want but the correct way is to remove the four wires from the push in connectors and then use a wire nut and add a short piece of wire to each group. Then connect the short wires to one screw on each side of the outlet. White to silver, black to bronze. The grounds will have to be pigtailed together too.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
cejkwo (07-01-2010)
Old 06-30-2010, 09:03 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 922
Yes, you can use the screws to add wire for another receptacle.
The problem you run into is the box may be too small code wise to handle another set of wires.
If you go throught the trouble of adding more wires, the use the pigtail to make the connections.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
The Following User Says Thank You to jbfan For This Useful Post:
cejkwo (07-01-2010)
Old 07-01-2010, 09:00 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 23,842
Yes you can add another wire to the screws. Most will recommend not using the pushins. They are a very common cause of open connections.
The Following User Says Thank You to joed For This Useful Post:
cejkwo (07-02-2010)
Two hot wires to same outlet yeterp Electrical 7 08-01-2009 07:18 AM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 12:53 PM
Outlet neutral bonded to ground? rjniles Electrical 1 07-19-2008 11:12 AM
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 08:08 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
