3-Phase Distribution Panel - Electrical - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By The-SPeculator
  • 1 Post By COLDIRON
  • 1 Post By Shadow99
Old 12-12-2017, 05:33 AM   #1
Mexican Electricity....
Rewards Points: 4
Morning All!
This is quite an involved question so will outline the background first.
I am renovating a house in Mexico and need to first update the main incoming distribution panel.
The house has 3-Phase supply with three analogue meters(CFE, Mexico electrical authority upgrading to digital with appropriate neutral and grounding)
I will end up with new L1, L2, L3 and N meter tails.
As some of the renovation work will entail the use of building equipment with 3-Phase motors (cement mixer etc) i would like to install a 3-Phase (and 240v) sockets.
Now, the bit I am unsure about is that I would like to have a master board at the house gate with the 3-Phase and auxiliary sockets and then the three lines are distributed to various places in the property where there are three independent sub-distribution panels with all the MCCB, RCD, MCB's etc.
The three areas are:
* Main house
* Bedroom Wing
* Guest house and garage and single phase water pump
How would the master board be wired? would the following be correct?
Power from meters/outside
N L1 L2 L3
Disconnect Schneider INS125 4P
N x x x 3 100A fuses on Line, (they like fuses in Mexico...)
------- L3 to Main House ----Sub board with protection and circuits
--------- L2 to Bedrooms ----Sub board with protection and circuits
----------- L1 to Guest, Garage -Sub board with protection and circuits
63A MCCB 4Pole Schneider LV429572
3-Phase
Socket
any thoughts or comments much appreciated
Regards
TC
The-SPeculator is offline   Reply With Quote
Old 12-12-2017, 06:05 AM   #2
Rewards Points: 2,010
Re: 3-Phase Distribution Panel
The house your referring to has to be a farm, industrial building, commercial building.
Your dealing with something that's not considered residential electrical. At least in the USA.
There are many experienced people on this site that know 3 phase wiring .
I think it's in your best interest to call a Pro Electrician.
The work your considering needs a licensed Pro.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 12-12-2017, 06:17 AM   #3
Rewards Points: 4
Thanks Coldiron,
No, it is a house, on an acre of land.
3-Phase is quite common here in Mexico and also in my home country of New Zealand, albeit that is 230v system of course.
The quality of wiring here leaves a lot to be desired. I'd rather get a solution to present to a "professional" rather than ask them outright
Blue Marjan likes this.
Old 12-12-2017, 07:22 AM   #4
I was not aware of the Electrical Distribution system in Mexico.
Maybe someone will come along and answer your questions.
Although I have been involved with 3 Phase for many years in industrial and commercial properties and Mechanical systems. I will leave this to someone much more experienced in this than me. Good Luck I am out.
The-SPeculator likes this.
Old 12-12-2017, 09:23 AM   #5
CodeMatters's Avatar
Rewards Points: 6,142
Don't know if this will help but up here the simplest way to do this
would be something like this:
meter- fused disconnect- splitter -4 fused disconnects - to sub-panels
Can't find a picture online but the 4 fused disc's would usually sit side
by side beneath the splitter with 4 conduits connecting them to the
splitter.
CodeMatters is online now   Reply With Quote
Old 12-12-2017, 01:01 PM   #6
Deleted Member
Shadow99's Avatar
Rewards Points: 858
Originally Posted by The-SPeculator View Post
Thanks Coldiron,
I'll second @COLDIRON Get 2 or 3 guys out to get ideas/quotes.
Nobody can approve your disconnects/loads without a load calc.
Also, you have 120V going to the house/guest/garage ?? (w/o disconnects as well)
Not a DIY project IMO.
Paulusgnome likes this.
Shadow99 is offline   Reply With Quote
Weird 3 phase panel ionized Electrical 4 01-27-2014 06:01 PM
3 phase panel and single phase service macster44 Electrical 5 01-07-2014 10:21 AM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
Single Phase Sub Panel from 3 Phase Power supply The Quan Electrical 1 10-30-2011 06:50 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
